The Unsettler
I thought it was code to have a battery, wired or not. If not seems like it should be.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
least common denominator
That is because all new smoke alarms upload to the military satellite system that informs them on exactly when to go off at the most inconvenience time... and sends a live video feed to a semi-secure internet site (and may I say you look quite fetching in those lepard print boxers!)
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
And... I just changed out my smoke detectors... and they all came with ten year lith ion batteries.
A few bucks more but worth it IMHO.
Misunderstood User
Truth be told, I have one electric with a battery and 2 without. I specifically bought w/o because one of my detectors is in a room with a 14 ft ceiling that is an absolute PITA to get at.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Un-Registered User
I have 8 detectors with battery, wired together. If one goes off, they all go off. It's code here.
Don 1988 Targa |
The Unsettler
Going to assume those no battery detectors either have the long life lithium back up that does not get changed because they last the serviceable life of the detector or they have a capacitor.
The problem described sounds as if there is either a bad detector or bad battery. Are they linked detectors where all sound if there is an event? Vin
'07 Cayman '90 911 - SOLD '05 Boxster (for the wife!) '85/1 944 - SOLD |
Targa, Panamera Turbo
I threw the breaker, all detectors off, changed all batteries, fired up the breaker - so far, no false alarms. House is always kept at 73 year round.
The sat feed (if real) would explain other things!
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
You forgot to water your plants... and your wife has been sampling your bourbon.
now I know your full of shyt! I don't have any house plants left (dogs, long story) and my wife hates bourbon, whiskey, scotch but if you said Vodka you would have had me thinking you were black op'n me!
I have to confess I turned my smoke detectors off and removed the batteries. They are hard wired, with battery backups and linked. I tried changing the batteries, replacing some of the detectors, going without batteries - house current only, going with batteries only, and nothing helped. There was always one that started chirping in the middle of the night. I'd be going around in the middle of the night standing and looking up to see which one was flashing the big red light. Once in a while one would go off for no reason and set the others off. It was a big enough irritant, I figured they just made them that way and decided enough was enough.
Marv Evans '69 911E |
Parrothead member
I have a smoke detector in every room in my house including my garage. I don't want to miss anything. I may be paranoid, but 27yrs in the fire service will do that to you. I've been to more than enough fatal fires, that didn't have working smoke detectors. .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I replaced them all last year (9 of them) and at $65 each. So far the new batteries seem to do the trick.
I did the ten year battery thing too. Around here landlords have to have working smoke alarms in rentals so the ten year thing makes it easier.
Platinum Member
They are not made that way, it was likely end of lifespan, or dirty.New detectors are about $14 each. Add a CO if you have any gas appliances in the house for another $30 We install in every new house, and add bedrooms, etc in every remodel. Never have callbacks, they work. |
Maybe I will replace all of them. They are about seven years old at this point. I did replace two, and they just seemed to fall in with the others in terms of the irritating behavior. The place is all electric and not fire prone, but I would feel better if they actually worked.
All detectors currently on the market will be changing over the next few years. The national code for detectors has changed and detectors will have to become more sensitive to Polyurethane Foam smoke and less sensitive to nuisance alarms (burnt toast). Make sure your detectors are working, it's the smoke that kills in most fires, not the flames and modern materials give off a lot of it when burning.
