-   -   Fixing a radon problem (http://forums.pelicanparts.com/off-topic-discussions/924728-fixing-radon-problem.html)
cgarr 08-08-2016 12:09 PM
anyone have high radon levels in your house? Finished basement so we really cant go back and seal the concrete. How do the vent systems work where you draw a vacuum under the slab work? Any good ideas? Levels are twice the high rate:
wdfifteen 08-08-2016 12:12 PM
My wife had to have one of these negative pressure systems installed when she bought her house using FHA. It seems to work. Subsequent tests always showed levels in the basement below the limit.
Radon Mitigation - SYSTEM DESIGN BASICS
cgarr 08-08-2016 12:26 PM
Thats the system I was looking at but this link explains it good! Thanks
wdfifteen 08-08-2016 01:19 PM
I should add that her house had water intrusion through the basement walls (walls are not airtight) and a sump that is not sealed. The system still kept the radon levels under the maximum.
MBAtarga 08-08-2016 07:37 PM
Our house (bought 4 years ago) has a system installed from the previous owners/builders.
Draws air from 1 pipe under the 3 car garage slab via basement wall access, and another pipe under the basement slab itself. It runs 24 hrs/day - 365 days a year. Each vented area is backfilled with gravel to allow "air" space.
72doug2,2S 08-08-2016 08:00 PM
Easy to reduce crazy high levels, hard to reduce low levels.
What is your level?
