Team California
speeder's Avatar
Best undercoating for salt driven cars?
I'm going to be running a couple of older rigs in salt country this winter, both are rust-free as of now but not built to be rust resistant like newer cars are.
I also know that there is no way to truly rustproof a car in MN., (I grew up here), just trying to do what I can to slow the progression. My plan is to steam clean the crap out of the undercarriage and wheel wells, sand the pan down and coat w red oxide primer, then undercoat it and lots of trips to the coin car wash in winter.
It's actually possible to severely limit rusting w fastidious power washing of vehicles here but most don't do it. The coin car washes here pump hot water, it's awesome.
I'm thinking of something I can brush on? I know that Wurth used to sell one, any experience here? Fire away!
Denis
Old 09-15-2016, 09:50 AM
dlockhart's Avatar
The sprays look interesting for getting into the nooks and crannys that always seem to be rust issues. ( like the wheel arches on ford superduty boxes )
Cosmoline for Sale - Cosmoline Direct Rust Preventives, Sprays & More
"The primary contribution of government to this world is to elicit, entrench, enable, and finally to codify the most destructive aspects of the human personality."
Jeffrey Tucker
Old 09-15-2016, 09:56 AM
Control Group
Tobra's Avatar
Cosmoline is what they use on guns, should work well. My uncle used to spray oil on the underside of his in Nebraska.
Old 09-15-2016, 09:58 AM
fastfredracing's Avatar
We have a few places that do used motor oil undercoating. They mix something else in with it to thicken it up a little bit. It constantly runs, never hardens and gets down in all the little nooks . This is by far the most effective thing I know of. It is super messy, and you will hate working on your car after this , but it works . The people who I know that use it , seem to have the best luck with rust prevention.
Without anything applied, your cars will turn to dust in two seasons here .
I think there is also an undercoating product called LPS, same deal, it never totally cures. It will drip out of the seams on a hot day .
Welcome to the rust belt !
No left turn un stoned
Old 09-15-2016, 10:03 AM
Transmission fluid, Varsol and wax.
Heated slightly it sprays on and stays in place.
Old 09-15-2016, 10:05 AM
Yes , and lots of washing. I do the same thing, I try not to let any of that crap build up in the wheel wheels, and on the rocker panels .
Every few days , $2.00 at the car wash, and you are good to go . Gawd, I hate winter . Just around the corner
Team California
speeder's Avatar
Thanks! Used motor oil won't work for me, too messy and I'd be power washing it off all the time. I'll look into the cosmolene.
Denis
Old 09-15-2016, 10:08 AM
MAGA
Tim Hancock's Avatar
Fluid Film.... I bought a gallon this past winter along with the applicator gun to apply to my recently purchased used 2011 Toyota Tundra. It is a lanolin based product that is applied to the underside of the vehicle. It can also be sprayed into doors. It remains wet for the most part but even if it gets wiped off, a waxy film remains. It used used a lot in Canada and northeast states. I will reapply at least once a year. My first thorough application this past winter required a little over 1/2 gallon.
Long term, the old school rubberized undercoatings can trap moisture which is why I researched the issue and found that Fluid Film is highly regarded by most everyone who uses it. A quick google search will tell the story.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 09-15-2016, 10:09 AM
Embraer's Avatar
Waxoyl
-mike
Old 09-15-2016, 10:35 AM
Un Chien Andalusia
Aerkuld's Avatar
Originally Posted by Embraer View Post
Waxoyl
^^ This was what we used to use in the UK on the old Mini. It can be sprayed from a long tube which you can fit into all those moisture traps. Seemed to work pretty well.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 09-15-2016, 10:43 AM
Agreed. The Cosmoline Sprays are ideal. We just got their newest spray....RP-342 "Heavy" (military-grade Cosmoline version)......best aerosol solution, hands down.
Detached Member
Hugh R's Avatar
No expert here, but as I understand it, the salt only corrodes when its in a wet (not ice) environment. So frequent power washings go a long way to avoid the rust thing. The salt and, while frozen stuff, doesn't affect it too much.
Hugh
Old 09-15-2016, 10:46 AM
T77911S's Avatar
pull bumpers off and taillights and hose all the sand and dirt out from the areas where it gets stuck and moisture can remain.
also hose down the inner fender wells really good.
other than that you need to do the above, remove any lose undercoating and apply wurths.
you don't want to seal in any moisture or dirt.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-15-2016, 10:52 AM
id10t's Avatar
The 356 talk list swears by POR15 for new/replacement undercoating. Maybe a spray on thick finish like rhino liner (truck bed liner) ?
Cosmolene will wash off if you are power washing with warm/hot water...
Old 09-15-2016, 11:17 AM
FUSHIGI
maybe consider buying a reliable sacrificial appliance.
Old 09-15-2016, 11:25 AM
D idn't E arn I t
RANDY P's Avatar
Waxoyl
Redneck waxoyl:
Diesel, ATF and wax
https://discoweb.org/forums/showthread.php?t=26892
AOC/Hogg 2028
Old 09-15-2016, 11:33 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by RANDY P View Post
Redneck waxoyl:
Diesel, ATF and wax
I like it.
If speeder only wants to do the underside a homemade schutz gun should do the trick.
1981 911SC Targa
Old 09-15-2016, 11:43 AM
MAGA
Redneck waxoyl:
Diesel, ATF and wax
I tried this first and hated it. The melted wax would start to solidify in my squirt bottle as it cooled. I also tried it using an old siphon cup paint gun and the wax would solidify in the tip as it cooled from the air passing through it. After searching online some more I said screw it and just went with the proven Fluid Film and their modified undercoat gun.
0% Liberal
Old 09-15-2016, 12:39 PM
D idn't E arn I t
RANDY P's Avatar
Originally Posted by Bob Kontak View Post
I like it.
I was thinking a giant paint brush myself....slap a bit in the wheel wells and in the arches and hidden nooks and crannies.
rjp
AOC/Hogg 2028
Old 09-15-2016, 12:45 PM
least common denominator
scottmandue's Avatar
Being a native Cali boy I know nothing about undercoating, but I have seen 4x4 guys spray their whole truck with bed liner.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 09-15-2016, 12:51 PM
