Targa, Panamera Turbo
M.D. Holloway's Avatar
Sonoluminesence
Sonoluminescence experiment: sound into light
Now this is pretty cool.
Imagine you take a vial of liquid and run sound waves through it intense enough to create a bubble, a process called cavitation. Since the newly formed bubble is a very low-pressure area in the middle of the higher pressure of the liquid, it will quickly collapse. As the bubble bursts, crazy, inexplicable stuff happens. First, the interior of the bubble gets insanely hot. Laboratories have measured the center of the bubble at thousands of degrees, with recorded temperatures going as high as 20,000° Celsius. (To compare, the surface of the sun is only 6,000 degrees Celsius.) At the same time, you can detect a flash of light in the center of the bubble—usually bluish in color—lasting for just a few trillionths of a second. This flash of heat and light is sonoluminesence.
https://blogs.scientificamerican.com/guest-blog/stuff-physicists-don-t-understand-sonoluminesence/
Michael D. Holloway
https://5thorderindustry.com/
Old 10-16-2016, 07:34 PM
White and Nerdy
Tervuren's Avatar
Yo dude, like I love it man when scientists cause, like, you know to have that crazy, inexplicable stuff happens things goin' on their laboratories. I love it even more man when they tell us of all this crazy, inexplicable stuff happens as its goin' on. Gives me like, faith you know in crazy, inexplicable stuff.
Shadilay.
Old 10-16-2016, 08:47 PM
Max Sluiter
Flieger's Avatar
cool, I love science
Old 10-16-2016, 10:39 PM
DanielDudley's Avatar
Wait. Vibrations contain energy ? Must be some pretty intense vibrations.
Old 10-17-2016, 01:41 AM
I didn't read the article, it may have mentioned this, but one of the fastest moving animals in the world uses this to stun it's prey. It's a shrimp that has a club, but they think the bubble and consequent shockwave that really does the work more than the club itself.
Old 10-17-2016, 04:00 AM
Laneco's Avatar
Oh wow that's COOL Mike! My inner geek is in full glee!
Science is SEXY!
angela
Hello
Old 10-17-2016, 06:17 AM
Unregistered
sammyg2's Avatar
Vibrations can be viewed as a language and if you go to school long enough you can learn to understand that language and the vibrations will tell you a story!*
*card-carrying Level III Vibration analyst, certified in accordance with ISO 18436-2
Old 10-17-2016, 12:35 PM
Unregistered
sammyg2's Avatar
Typical capitation signature from a centrifugal pump suction.
Note the elevated floor on the spectrum and random non-repetitive waveform:
Old 10-17-2016, 12:38 PM
Rickysa's Avatar
Mantis shrimp....affectionately referred to as "thumb splitters" in the reef-aquarium hobby
Because they strike so rapidly, they generate air bubbles between the appendage and the striking surface-known as cavitation bubbles.[9] The collapse of these cavitation bubbles produces measurable forces on their prey in addition to the instantaneous forces of 1,500 newtons that are caused by the impact of the appendage against the striking surface, which means that the prey is hit twice by a single strike; first by the claw and then by the collapsing cavitation bubbles that immediately follow.
...wiki
Rick
'89 Targa
Old 10-17-2016, 01:38 PM
