RETIRED
How best to drill a lock hole for a tool box?
How best to drill a lock hole for a tool box? Pilot holes, punch and a file?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
If it's just a cheapo tool box, then I'd drill a pilot hole and use a sawzall to cut most of it, then finish with a drum sander. Or better yet, weld a hasp on it so that you can put a big ol lock on there.
If it's an expensive tool chest, then I'd take it to a metal guy who can spend time making it perfect. |
Option B: Find a different lock that is perfectly round?
RETIRED
They are all like that. It keeps the lock cylinder from spinning with a key or a screwdriver when attempting to break in.....
I am guessing that template above corresponds to just the rear portion, which is threaded for a retaining nut, yes? And the front has a bezel/ring that is larger in diameter?
If that's the case, you should be able to drill 1 single hole, the same size as the lock body. No need to make it the exact shape. Just make sure the lock nut is cinched down good and tight. I'd probably use Loctite on the threads as well. YMMV... |
A drill, a sabre saw, a fine metal blade, and a couple of files or a dremel. Tape the face of the box. Back in the dark ages a guy would drill a bunch of 1/8'' holes around the perimeter, and co to town with a file.
My guess is that there is a die for that that has a bolt that goes into a small centered hole, and then gets cinched down. With the above tools, I could have a nice quality hole in about 30 min. or less. |
Cheapest double D punch I found was 157 dollars.
There is probably a locksmith within 50 miles of you that has one. |
Platinum Member
I'd drill a hole the size of the flats, then elongate it with a dremel.
Don't suppose you have access to a nibbler? http://www.homedepot.com/p/SPEEDWAY-16-Gauge-Capacity-Air-Nibbler-9943/203185226?cm_mmc=SEM|THD|google|&mid=sGGzTBmKX|dc_mtid_8903tb925190_pcrid_111416414 825_pkw__pmt__product_203185226_slid_&gclid=CPC8udKQz9ACFVdMDQodBKUCzw |
Just drill a round hole. Stick the lock through and JB Weld the heck out of it before installing the washer and retaining nut.
Super Moderator
I think I'd go with an external latch vs trying to cut a hole like that. Why are you committed to this style?
I'm just going to point out that there are guys over in the technical forums who do harder stuff than this every day. Care and patience often can substitute for fancy tools. But I would get on the phone and let my fingers do the walking while I talked to some local locksmiths.
RETIRED
RETIRED
I don't want externals punching holes in the pups or the cushions, it gets messy and vet bills be 'spensive....
RETIRED
That HPC punch is what I need. Will call around to see if any shop will do it for me. Can't see dropping that much $$ is worth it to me at this point.....unless my display guy would use it.
Platinum Member
Get this, $3
![]() If in wood, countersink, if thin metal then drill round hole and rivet this on the back side. |
With fierce guard dogs like that, who needs a lock?
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
I have carpet on mine, with a recessed spring loaded handle to open the door. The sub woofer is on the driver's side.
RETIRED
That's good idea for the door.
I found a locksmith to do the hole punch. Waiting on a Pelican to come by and pick some bumper parts, then off to get "punched".....film at 11.
RETIRED
Crud....they wouldn't do it because it was too thick a material and in the car......back to drilling and filing.....
