Cliff Ruggles has the world's biggest backlog. I'm thinking of Sean Miller for my next QJet. I've got a 750DP that works fine on my pontiac, but still the idea of a Q-jet for part throttle is appealing. I just can't get the damn Q jet to quit being so finicky about fuel pressure. I need to upgrade my delivery system.
Today's tip from the 50's: You're doing it wrong. Cast iron Chevy exhaust manifolds aren't meant to have gaskets. iron-to-iron only.Throw away the silver Fel-Pro gaskets that burn out all the time. |
me like the Q-jets.
anyways, once upon a time, i had an open chamber big block with a tunnel ram, wouldn't idle worth ****. we threw on an msd ignition module, and it would fire right up and idle like a champ. some serious spark action there. |
Excellent post. |
Further - there were actually 800 CFM versions that only came OE with certain hipo Pontiac / Buick / Olds. Those are the ones to use in performance street engines larger than 400 CID. |
I believe there was over 10k versions over the years. Many people have screwed them up by mixing and matching pieces. Cadillac's also had large CFM Q-jets. |
| All times are GMT -8. The time now is 01:59 PM. |
