Small Block Chevy does NOT like the Cold.
I rebuilt the small block chevy not too long ago to put in my truck. Pistons, rings, bearings, cam, valves, ignition, and a quadrajet rebuilt by Cliff.
Ever since it has gotten cold, it feels and sounds like a mis-fire until it warms up all the way. I pulled the plugs and they're OK, if a little rich, but still ok. At cold start-up I can hear a mis-fire out of time bang,clank, in the passenger side long tube header, but then after it warms up, it goes away and sounds fine. Any ideas where what to check? I'm thinking maybe ignition wires need to be sorted a little less tangled? It's only on that one side. |
I'd think exhaust leak or an intake manifold leak- without being being there to hear it myself.
Retorque everything. |
Check it out in the dark around plug wires and look for arcingSmileWavy
cool, thanks, good ideas to start
If your wires were arching you would most likely have the problem all of the time. What type of choke is on the car? It might not be adjusted properly. Did you check the choke before starting the car when it is cold and make sure it is actually closing all of the way?
that popping is air getting into the system somewhere...
Lean misfire perhaps since the engine is still cold. Does it pop back through the carb? Carbureted engines don't run well until they are warmed up. Fuel injection has spoiled us.
The quadrajet is and always was a piece of crap.
Describe your cold start procedure. What does it take to get the truck to start when it is cold?
Pump the pedal all the way to the floor 3 or 4 times B4 turning the key. Make sure choke is adjusted properly. Cold engines require more fuel. Ur not getting it.
I have some cars that miss on cold startup, I attribute it to plugs being wet from either condensate, coolant, or fuel Since it doesn't persist I haven't figured it out totally. I suspect it's water because when it quits missing I immediately see more steam out the exhaust.
So, I'll try richening the idle mixture on that side. I remember leaning them both a while ago.
Cold start procedure, three or four stomps to set the choke , then it fires right up in just a few cranks !
SmileWavy _ |
Thanks Norm, that's what I was thinkin
Good luck! _ |
Carbureted intake manifold leak could create a miss-fire or weak-fire at a specific cylinder. Given heat that is in the 200F (intake) vs 500F (exhaust) range I am not seeing 200F heat sealing off an intake leak (intake to head) that is big enough to create a noticeable miss. Just talking. OP could always try the carb/brake cleaner spray test. |
| All times are GMT -8. The time now is 09:02 AM. |
