-   -   2000chevymalibuLs Help from best mechanic (http://forums.pelicanparts.com/off-topic-discussions/940767-2000chevymalibuls-help-best-mechanic.html)
Rajari5707 12-30-2016 06:55 AM
I have a 2000 Chevy Malibu LS that won't start it slow cranks.Still the engine doesn't turn over. Have an obdll scanner and was sent a po107 code.The codes for a map sensor/barometric something.Need help from the best mechanic!The valves inside the engine don't crank I looked thru the oil cap and the valves were exposed. I had some one crank the car while looking they didn't even budge.The car also sounds as something turningNeed the help
gshase 12-30-2016 10:30 AM
You say a 2000 Chevy Malibu.......Let me Google that for you.
stomachmonkey 12-30-2016 10:37 AM
1st post on a Porsche enthusiast board and he's asking about a Malibu with possible blown timing chain?
I have never, ever, in all my time here put anyone on ignore.
This might be a first.
stevej37 12-30-2016 10:51 AM
slow cranks..but won't turn over???
Arizona_928 12-30-2016 10:54 AM
Just fill the trunk with tannerite and leave it in Chicago. I'm sure you'll get one last movement "under its own power"...
gorthar 12-30-2016 11:52 AM
Hey, hey! He only wants help from the best mechanic!:D
Arizona_928 12-30-2016 12:39 PM
Fight to the death until the best mechanic is crowned. Lol
masraum 12-30-2016 01:31 PM
Weird. Seems like a troll.
https://tr.poshmark.com/closet/rajari5707
Valves aren't moving, but the engine is "cranking" (but not turning over), then that would point to a timing belt issue, except that it's a 3.1L V-6, so a timing chain. Still, those can go bad.
I think it just needs to be pushed to the nearest junkyard.
Norm K 12-30-2016 01:39 PM
I think what he really needs is advice and opinions as to which is the best oil for his air-cooled Malibu.
_
fastfredracing 12-30-2016 01:41 PM
<iframe width="560" height="315" src="https://www.youtube.com/embed/5F-VQtEfbTU" frameborder="0" allowfullscreen></iframe>
Dantilla 12-30-2016 02:12 PM
It's obvious the primulator is toast. Common problem with a Malibu.
While you're at it, replace the pfitzer valve. When they go bad, the first indication is when the primulator goes out.
masraum 12-30-2016 02:46 PM
Right, and when the pfitzer valve goes out, the car cranks really slowly, but then when the primulator is gone, it won't turn over, good call.
