You say the tank is 21.5" tall, but it seems to me most tanks don't get filled to the brim with water. And how much of the bottom is covered with gravel? I would assume that you might have 1" of free space at the top? Do you have 1" of gravel at the bottom? You'd need to subtract both of those from the 21.5". Technically, the gravel has water in and around it, but since we aren't going to compensate for the rocks/plants, lets just assume the gravel is essentially solid and the rocks plants displace the real life amount of water that's down in the gravel. So, if her tank is 21.5" tall, and we subtract 1" because it's not quite completely full, and then we subtract another 1" because the bottom is full of gravel, that would make a tank 19.5" tall. So, as stated previously 75 gallons per 19.5 inches (per means "divided by") so 3.84 gallons per inch. 3.84 goes into 15 about 4 times, so take 4" of water out and that should be about 15 gallons or 1/5 of the volume of water.
It is amazing the roundabout way some people have tried and still managed to come up with the approximately correct solution. Steve's was the most creative, and took the longest trip into the weeds before he came back to reality.
So Glen, bottom line you're looking at about 3.75 - 4" of water depth to equal about 15 gallons.
