Targa, Panamera Turbo
M.D. Holloway's Avatar
Perplexing Math Question...
If you get a spoonful of milk from a cup of milk and put it into a cup of coffee, then you put a spoonful of the mixed coffee back to the milk cup, what would be the amount of milk in the coffee cup? And the amount of coffee in the milk cup?
a) There will be more coffee in the milk cup than milk in the coffee cup.
b) There will be more milk in the coffee cup than coffee in the milk cup.
c) The amount of coffee in the milk cup will be the same as the amount of milk in the coffee cup.
(I found this on-line)
Michael D. Holloway
https://5thorderindustry.com/
Old 02-10-2017, 04:01 PM
There is no tricky part in this question. The two cups are identical. The same spoon is used in both transfers. There is nothing funny to catch. It doesn't even matter whether you stir up the cups after each move or not. You can stir up thoroughly, stir up a little, or do nothing to stir up, after each move. You can heat the two cups up, cool them down, or heat one up and cool the other down. You can do these two moves once, twice, or until you get nauseated. They all come out the same answer!
Michael D. Holloway
Old 02-10-2017, 04:04 PM
You can most likely find the answer on-line but try to think it through. I'll post the answer in a bit. At first it didn't seem to make sense but it actually does after some thinking.
Michael D. Holloway
Old 02-10-2017, 04:07 PM
FUSHIGI
If correctly answered as you indicated, the question isn't about coffee or milk as the choices indicate but rather it is about fluid volume and makes the excerise one of futility.
Old 02-10-2017, 04:19 PM
WPOZZZ's Avatar
I dunno, I drink my coffee black.
Old 02-10-2017, 04:44 PM
Eric Coffey's Avatar
The answer is: Keep your damn milk spoon out of my coffee.
Old 02-10-2017, 04:47 PM
id10t's Avatar
Eh, if it were all evenly mixed it becomes a simple "intro to chemistry" level question on solutions and dilution.
BUT... it uses tricky grammer and silent-p-sychology and the workings of the human brain to make it not what it may seem to be at first glance.
I'm a couple of beers in, and I'm too lazy to get up for a pad and paper...
Old 02-10-2017, 04:51 PM
look up 'entropy of mixing' ...
Michael D. Holloway
Old 02-10-2017, 04:52 PM
b.
Old 02-10-2017, 05:02 PM
wdfifteen's Avatar
It's B
Old 02-10-2017, 05:10 PM
non-whiner
mreid's Avatar
B, pure milk went to coffee, diluted milk came back.
"Too much is just enough."
Old 02-10-2017, 05:32 PM
SPOILER ALERT - AVERT EYES IF YOU DON'T WANT TO KNOW JUST YET...
The answer is c) The amount of coffee in the milk cup will be the same as the amount of milk in the coffee cup.
Proof: The 2nd spoonful is not 100% coffee, as opposed to the 1st, which is 100% milk.
The 2nd spoonful is (100% - X%) of coffee. The coffee that is moved to the milk cup is not enough to balance the milk that was moved to the coffee cup in the 1st spoonful. But, that means X% of milk is also moved back to the milk cup, which is the exact amount that is needed to balance the discrepancy and make them even. The 2 balance out to equal measures.
Michael D. Holloway
Old 02-10-2017, 05:47 PM
The Stick
RKDinOKC's Avatar
That's Dilutional.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 02-11-2017, 05:48 AM
wdfifteen's Avatar
Cup 1 has 10 units of coffee
Cup 2 has 10 units of milk
Remove 1 unit of milk from c2 and add it to c1
C1 has 11 units of mixture, each unit is 0.090909091 units of milk and 0.909090909 units coffee
C2 has 9 units of milk
Add I unit of c1 mixture to c2
C2 now has 9. 090909091 units milk and 0.909090909 units of coffee
C1 has 0.090909091 units of milk and 9.909090909 units coffee
Old 02-11-2017, 06:19 AM
the cups are quantum entangled... ask the LHC
Old 02-11-2017, 05:14 PM
Non Compos Mentis
We must also calculate thermal expansion and contraction.
What is the initial temperature of the coffee?
What is the initial temperature of the milk?
In degrees Celsius, to 0.000 significant figures, please.....
Old 02-12-2017, 08:27 AM
Team California
speeder's Avatar
That's Dilutional.
Winner.
Denis
Old 02-12-2017, 09:02 AM
gchappel's Avatar
Oops- misread the question. This does confirm the answer is the same.
Let us say, just to keep the math easy- that one spoonful was 50%. The amount taken should not change the math.
So you start off with 100 units of milk and 100 units of coffee.
Take out 50% of the milk and add it to the coffee.
You now have 50 units of milk, and 150 units of coffee/milk mixture.
Now take out 50 units of the coffee/milk mixture.
That is 1/3 of the new volume
16.67 units of milk (1/3 of the 50units of milk), and 33.33 units of coffee ( 1/3 of the 100 units of coffee).
You are left with 100units of milk/coffee. 66.66 units of coffee and 33.33 units of milk.
When you add the 50 units of coffee/milk mixture to the original 50 units of milk-
You would have- 33.33 units of coffee and 66.67 units of milk.
Gary
Old 02-12-2017, 12:28 PM
The Stick
RKDinOKC's Avatar
Aint gettin my unit anywhere near hot coffee! Milk? The kind and container(s) make a difference.
Old 02-12-2017, 01:18 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Lets see, 1 aught+one naught=equals a aught not!b
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 02-13-2017, 09:38 AM
