RETIRED
ID 12 volt pins, please
I have a 12 volt power supply. I can charge it but would like to use it to have back up power that has a USB port, like a cell phone or a camera. Can someone ID the pin connectors in the pic? Bonus points to where I can get and adapter fror that pin to a male USB pin....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
Pin that I need to plug into camera or cell.
The first picture looks like a pretty standard 2.5mm barrel jack. I get 12VDC power supplies from powerstream.com, myself, but Amazon has them too.
The second is tough to tell from the picture, but it looks suspiciously like a micro-USB. So are you looking for some kind of adapter that will supply 12VDC through a micro-USB? My knowledge of this is limited, but I thought USB was limited to 5VDC, so I'm not sure how that'd work. What am I missing?
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
RETIRED
I wish to power a Garmin dash camera beyond the 1 hour internal battery life. The unit has the 2.5mm barrel jack. The Garmin plugs into my cig lighter and uses straight 12volt power.
I want to use the Garmin on a bicycle and the ride would exceed the 1 hour life of the internal battery.
RETIRED
I need the male MINI USB, not the micro. I did a few searches....Is this what I need?
Type C Female Jack Plug to Mini USB Male Power Charger AdapterUse any 5V, Multi-voltage charger to power your device Note:You must make sure power supply is correct voltage for your device. This adapter DOES NOT come with any power supply - It is an adapter tip ONLY. I think this is what you are after - just cut the jack from your PS and make sure to observe polarity of the 12V connection wiring:
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Why not just get one of these?
https://www.amazon.com/Tzou-Cigarette-Lighter-Socket-Adapter/dp/B001TXWNLQ |
RETIRED
This is the power supply. 12.5v output, like my ciggy lighter. BUT I will be on my bicycle.....no battery and no engine.
