-   -   Long Shot Craftsman Tool Box Question (http://forums.pelicanparts.com/off-topic-discussions/954239-long-shot-craftsman-tool-box-question.html)
Gogar 04-22-2017 04:22 PM
All mine have numbers 8xxx sorry
wdfifteen 04-22-2017 05:54 PM
Those are only 3 or 4 pin tumblers. Easy to pick. Grind a small Allen wrench down so the short end is 1/8" long, stick it in the hole and rake it in and out against the pins while gently turning the tumbler with a small screwdriver. It should take you all of a minute to get in.
dad911 04-22-2017 05:58 PM
1/4" drill bit, 30 seconds. Replace, it's likely a standard lock like this ($5):
Prime-Line 7/8 in. Chrome Drawer and Cabinet Keyed Cam Lock-U 9943 - The Home Depot
http://www.homedepot.com/catalog/pro...a661a4_145.jpg
Brian 162 04-22-2017 06:08 PM
I once used 2 paper clips to pick a lock for a pool table. I inserted the straightened paper clip into the cylinder. While holding the first paper clip I inserted the other paper clip and rotated the lock cylinder. It actually worked.
I learned this from watching The Rockford Files.
stomachmonkey 04-22-2017 06:27 PM
Seriously those are some of the easiest locks to pick.
Paper clip to brush with and anything else to apply torque with.
Insert paperclip and you'll feel the pins push up. Withdraw slowly and you'll get a feel for them dropping.
The idea is to get them pushed up then apply torgue. As the pins drop they will get bound outside the cylinder. You can feel it happen.
You just keep torque applied to keep pins bound and go back and work th rest.
As a newb Expect you'll only bind on or two pins per brush stroke.
Even still, once you understand the concept should take you less than 5 minutes to pop your cherry.
Ayles 04-22-2017 09:04 PM
Thanks for the tips, been trying a bit and you can actually see them bind and not spring back down. Must be getting close.
Ayles 04-22-2017 10:09 PM
I got it!!!! Used a paper clip and hair pin.
Annnd its empty! But had the original bill of sale inside from Oct of 1982. I cant believe how heavy it is. Receipt says it weighs 116lbs. I also picked up a ton of NOS in package and unused tools from the era. Will post pics if any one is interested.
http://forums.pelicanparts.com/uploa...1492923896.jpg
http://forums.pelicanparts.com/uploa...1492923955.jpg
http://forums.pelicanparts.com/uploa...1492923979.jpg
http://forums.pelicanparts.com/uploa...1492924008.jpg
pwd72s 04-23-2017 12:09 AM
Congratulations! Now that it's open, should be pretty simple to install a new lock with key if you wish. Or, just never lock it?
KFC911 04-23-2017 12:30 AM
I've been planning a job down at the local Wells Fargo....you in :)?
daepp 04-23-2017 12:41 AM
Damn - for a second there it felt like a Geraldo story...
tabs 04-23-2017 04:06 AM
It was a Geraldo story. There was nothing in it.
gr8fl4porsche 04-23-2017 05:04 AM
I have the same toolbox.
It's been serving me well for two decades.
Baz 04-23-2017 06:34 AM
This thread prompted me to check the local CL for tool boxes....wow....no shortage of them there!
I already have one of those tall ones with a million drawers so I'm good for now but I found a little one that included a wide variety of tools - all made in the USA - so may pursue that one just for patriotic purposes! :)
Ayles 04-23-2017 07:57 AM
Any ideas on the value of a 35 yo perfect made in the USA tool box?
Ayles 04-23-2017 08:01 AM
I would never have expected it to weigh that much empty!
CurtEgerer 04-23-2017 08:17 AM
Here's mine, well used. Different key 4012.
http://forums.pelicanparts.com/uploa...1492960631.jpg
Tobra 04-23-2017 08:40 AM
Now that it is open, you could probably take the lock out and get keys made, though it may be more economical to just replace the lock.
Ayles 04-23-2017 09:21 AM
Great looking tool box!
Ayles 04-23-2017 09:24 AM
It's pretty clear how the lock goes in, I will replace for sure if I cant track down a key. It seems as though the locks with a W on them may be from a company called Waterloo. I shot them an email so maybe it will pan out.
pwd72s 04-23-2017 10:26 AM
No idea monetarily, but a very useful item to have and use. Great find! By the way, do post pics of the tools. Snap-on snobs would disagree, but for home use, Craftsman used to make some damned good tools. Operative word used to. Look for "forged USA"..
As far as heavy, I agree. It was a struggle to get the top chest onto my 3 chest Craftsman rollaway. I went with the ball bearing drawers with the "griplatch" feature. This allows rolling the unlocked stack without fear of drawers opening.
