Originally Posted by Bob Kontak View Post
I am interested.
Had a sensor put in a newer Suburban last week. The guy did something on the dash first and walked around the car with his gizmo. The horn beeped when he pressed a button at each corner.
Was that the re-learn procedure or should you be able to do that with the car's brain alone?
You're sure there wasn't a midget hiding in the driver's seat, playing a trick on you?
Old 04-25-2017, 03:26 PM
Fleabit peanut monkey
Bob Kontak's Avatar
You are messing with a guy on the edge.
Originally Posted by rwest View Post
I think some cars are able to learn on their own, mine nope, I did several internet and YouTube searches and it all pointed towards needing to upload and that agrees with what I've seen at Discount Tire- guy walks around to each wheel and then plugs the tool into the OBD port.
Guy had a brand new Snap-On gizmo. No wires. Smelled of $800.
I will call him in the morning.
Seriously, I get more of these TPMS sensor problems than I ever anticipated. I want the tool but I don't know how it works. The cheap one. Not the howitzer.
1981 911SC Targa
Old 04-25-2017, 05:00 PM
Retired Member
Brian 162's Avatar
I am interested.
Yes I have one of those gizmos as well. When I swap my winter to summer rims the sensors have to be re-set. The sequence is in the owners manual.
I only paid $100 for the tool( Ateq VT5 reset tool).
Before I bought the tool I had to either let air out or add air until the horn beeped. When the horn beeps the car computer can now read the sensor.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 04-25-2017, 08:20 PM
Bob Kontak's Avatar
Good info. So at least some cars can be done without the tool.
1981 911SC Targa
Old 04-25-2017, 08:23 PM
Zink Racer
Manufacturers are different. My old Acura MDX would read new sensors no problem. Never threw a code. Toyota product I was told only hold one set of sensors in the computer, therefore each time you switch winter to summer and back, you need to have the sensors codes and re program them into the vehicle. Of course now I have a Tacoma and the wife's Lexus. I've just been having the tires swapped by the tire store but would love to get separate wheels for each. One can always pull out the black tape to hide the little flat tire on the dash I suppose.
Jerry
983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4
Old 04-26-2017, 06:40 AM
During my research, I came across a video of a Chevy Volt being done with the same tool I had bought and that car didn't need to have the info entered into the OBD port.
The Volt actually lit up the turn signal on the corner of the car that you where supposed to read next and then honked when it registered!
Tool should arrive tomorrow and I'll give a report.
Rutager West
Old 04-26-2017, 01:49 PM
fastfredracing's Avatar
Yep, I have that same gizmo, smelled a lot like $800.00. Sometimes I hate this business.
No left turn un stoned
Old 04-26-2017, 01:53 PM
Did it look like this ?
Old 04-26-2017, 01:58 PM
FPB111's Avatar
I have this one. It works for our Scion and Subaru. Initially you need to plug it into the OBD port to capture the tps codes that are in the car and save them as winter or summer. When you get new tps you need to get the codes from the seller. You then hook the unit up to your computer and load the codes into the unit as either summer or winter.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 04-26-2017, 05:33 PM
Bob Kontak's Avatar
Yes, Sir. It was a touch newer. I did call him today. He said it was in the $450 range. Maybe a bit longer in size. I am pretty sure I saw Snap-On on the box but he also has Blue Point tools.
He also said that the GM vehicles require the reset procedure but many (most) do not. It's a bummer I did not check out what he did with the dash buttons before he performed the procedure.
You are right with a bit of exception based on his input. That's what you get with an observer guy (me) that has a statistical mass of one car repair experienced.
If you would like me to find the population of cars that he is aware of that require it, I pass by his shop frequently. Would be glad to ask him and forward the info to you.
1981 911SC Targa
Old 04-27-2017, 04:00 PM
That tool is one Bad-ass B I T C H.
And no, I did not swear!
Old 04-27-2017, 04:11 PM
Guys,
A quick update of my own personal misery. I received the TS501 that is supposed to do the whole job- well it won't even read the sensors; I went through all the software updates just in case and still nothing. Started thinking maybe the sensors were "sleeping" or something, so I tried the TS401 I had gotten first and it read the sensors.
Aarrgh- spent hours on this stupid thing, probably, no, for sure would have been less hassle to have the tire shop just do it, but now it has become personal and I have to do it myself.
Sent an email to their support mailbox- we'll see.
Best,
Rutager
Rutager West
Old 04-27-2017, 06:34 PM
Jeff Alton's Avatar
With the right tool, a shop can opt to program a generic sensor for the specific vehicle requiring no further connection to the car. Or they can opt to program them through the OBD port.
www.turn3autosport.com
Old 04-27-2017, 08:40 PM
