The Unsettler
Educamate me, portable in room AC
My office is an oven.
Summer time is here and it's only going to get worse. After about 1 pm starts to become almost unbearable. I have two 12 ft high East facing windows and even though I have blackout curtains and heavy drapes it bakes in there. It's not the HVAC. I have 4 desktops, laptop, 5 monitors and miscellaneous other crap that puts out heat. There is literally a 15-20 degree difference between my office and the hall just outside. Thinking in room AC is my easiest solution. Anyone have experience with units they like, or hate?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Information Overloader
Don't get one that has a condensate reservoir that has to be emptied every 17 seconds it seems like.
Though that may not be a problem if the air in your building is already conditioned and dehumidified. You'll need a window to blow the warm air out of, too. |
I have one..they work ok, if you don't mind the noise.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Home of the Whopper
It is the A.C..
Measure discharge air temp and flow. Min 55f and 1 cfm per sq ft.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Run smooth, run fast
Do you keep the door to the hall closed?
If so, I suspect it's to keep noise out or to prevent family from wandering in and distracting you from your work. If that's the case, try putting a couple of 20" X" 20" vents in the door... one at the bottom and one at the top. If you could also put a box fan on the floor in the hallway blowing cooler air into the room, the warmer air would exit to the hallway from the top vent. If there is no outlet in the hallway, just put the fan inside and against the door and pull the cooler air in. If you don't keep that door closed, just do the same thing with the fan. Insulation, reflective tint, or something more to cover the windows would also help.
- John "We had a band powerful enough to turn goat piss into gasoline." |
The Unsettler
It's not the AC. Well yes in a way. It was not designed to accommodate the amount of hardware running in that room.
I'd likely need to convert the office to a 3rd zone. $$$$$$$$ Double french doors to the hallway, always open because cats. Family? I wish they respected a closed door. On evening conference calls I'll inform all family members that I have a call in a minute and I'd appreciate some quiet. Naturally they'll wait until 5 seconds after it kicks off to start yelling to each other from opposite sides of the house. For added drama my wife will usually stand right outside my office. Tried the fan in the door thing. Helps but not enough.
Home of the Whopper
This is in your house? Or office?
Either way you can shut off some air from other spaces to push more cold air into your office. Measure discharge air temp. Last resort, install a ductless mini split.
Platinum Member
If the ducts are accessible, a competent HVAC contractor can add ducts/vents, and zone your office.
minisplit might be a good solution
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
canna change law physics
Portable units pull air in from the room for the cooling in the system, so it is not closed loop.
The real solution is adding real closed loop cooling to the room. Option 1: Window unit. This may be a temp solution until option 2. Option 2: Mini-Split. They are very efficient and the install is not bad. Option 3: Add a 1.5 ton A/C unit for that room only.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Don't know if these are still available, but you get the idea.
Bought 3 at Home Depot for $300 each when up in Portland back in '09...two weeks of ungodly heat up there. One for my bedroom, one for the elderly couple's bedroom, and one for the living room. Sold one and have the other two here in AZ...used one in my patio for a couple of months...just parked next to us as we sat outside for hours at a time...made for an enjoyable patio experience in the 105' heat. You'll need a window vent and flex hose...those parts come w/the unit. . Really a sweet unit...all manner of features...controlled by the remote. Controllable louvers, sweeping or stationary blowing...etc., etc., etc. Makes super cool air. . https://www.amazon.com/SHARP-CV-P10PC-10000-Portable-Conditioner/dp/B003FL76XU/ref=cm_cr_arp_d_product_top?ie=UTF8 . ~~~~~~~~~ . .
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View Last edited by Don Ro; 05-09-2017 at 07:52 PM.. Reason: Mo info |
It'll be legen-waitforit
Only challenge is where/how to vent the hot air from the AC
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
The Unsettler
The space has an 18 foot ceiling. It was not designed for use as an office, it was originally intended as a library / reading, sitting room. The actual designated office is in another spot. The issue is not that the cooling is insufficient for the space, the issue is I have a lot of equipment that puts out a lot of heat in that room. For a variety of reasons anything requiring altering the existing HVAC is off the table. Hence my specific request for information re: stand alone portable units.
The Unsettler
The portables vent through a window, correct?
That would not be an issue.
A mini-split has an indoor and outdoor unit connected by a couple 3/4" or 1" hoses, doesn't need an outside wall. Has a small compressor that sits outside somewhere, like a regular hvac, but mini.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
I agree with Dad911 and Red Beard and all others. A mini split system will make your problem go away. It might even freeze your ass off
I am installing a roof-top mini split in my data room. I'm moving all heat generating stuff with the exception of computers into a room with a Mitsubishi mini split and heat pump. I am installing a roof top remote condensor also for a slushy machine for the same reason.
One of those window AC will do the trick but not nearly as efficient as the Minisplit. The window AC will more then take the edge off.
You need to think about noise.
Window shakers are relatively noisy. The Portable units are quieter but still make their presence known. A Split unit is fairly quiet. If it was me and you had a long term need, a split is the way to go to add a bit of spot cooling.
Old dog....new tricks..... |
