Math question
I need to get a ball bur to make a rivet set to fit these dome rivets. Head diameter is .324" and height is .067". Metric equivalents are 8.2mm and 1.7mm.
How do find the correct bur head diameter to make this shallow bowl?
Tru6 Restoration & Design |
.452 Dia.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Takin' hard left turns
If I understand correctly, you need the equivalent spherical diameter.
thanks! What is the math as I may have to do this for other rivets?
The radius of the head is 0.229350746 inches
Rick 88 Cab |
A google search for a circle from three points. I just put two points on the X axis and the other on the Y
Rick 88 Cab |
Unregistered
