-   -   building a man cave/garage need some advice (http://forums.pelicanparts.com/off-topic-discussions/958549-building-man-cave-garage-need-some-advice.html)
rfuerst911sc 06-02-2017 01:34 PM
Got a quote today for the concrete floor , 24 ' x 28 ' x 5.5 inch thick with two 3' x 3 ' pads 10 " thick for the two post lift total price $4,000.00 which I thought was reasonable . Unfortunately he's booked solid for three weeks but it gives me time to get the ground prepped/leveled and get some # 57 gravel spread . Will cover the gravel with plastic and wait for his arrival . I have decided not to recess the scissor lift as I am not 100 % sure I will take it with me , it may be a good selling feature for the house we are going to sell .
fred cook 06-02-2017 02:12 PM
Shop ideas...........
My shop is 24 wide by 28 long with a 12 foot wide carport on one end. The slab was poured as a 24' x 40' piece with the carport floor a couple of inches lower than the rest to keep water from the carport from coming in under the walk thru door. I also used a light cream colored roof to help keep it cool in warm weather. It is insulated on the walls and under the roof. The shop has a 6/12 pitch and is 12 feet high at the center inside. It is steel frame with sheetmetal walls and roof.
Put the electrical outlets at waist height or high enough to be higher than your workbenches. That way you can plug stuff in without getting down on the floor. When I had my shop built, I had the electrician run two 220 volt circuits. One was for the a/c - heat and the other is a spare for future use. I have one 120 circuit for overhead florescent lights, two for plug-in tools, one for two very large ceiling fans, one for outside lights under the carport and one for an outside double outlet. Not fancy, but meets my needs (so far).
I also agree with two doors instead of one. Having a 4 foot space between the cars will keep you from parking the cars too close together. I used a single 16 foot door and wish I had done otherwise. Also, I have no windows in my shop. the only opening are the overhead door, a walk thru door under the carport and two gable vents, one on each end. I would rather have a more secure shop than the natural light. I can always open the overhead door if I want to let the great outdoors inside!
Happy building!
DanielDudley 06-02-2017 02:12 PM
It is super easy to cap a recess later.
mikehinton 06-02-2017 03:24 PM
Maybe some solar tubes instead of skylights.
fred cook 06-02-2017 08:34 PM
Garage ideas.......
Found some pictures...............
http://forums.pelicanparts.com/uploa...1496460393.jpg
http://forums.pelicanparts.com/uploa...1496460610.jpg
http://forums.pelicanparts.com/uploa...1496460803.jpg
Dpmulvan 06-03-2017 07:46 AM
lots of cabinets and shelves suspended from ceiling. Store everything off floor. A good air drying system for compressor especially if your painting.
Seahawk 06-03-2017 09:22 AM
Can you tell me about the sword - I have my Fathers from a tour he did in Japan before i was born.
Originally Posted by fred cook (Post 9611641)
Nice place, btw.
To the OP. I am about to head up and clean the 79x19 place up after a winter and spring of heavy use.
As Dpmulvan mentioned, get every thing off the floor.
