996 With White Smoke
I am looking at a very cheap 996 with 120,000 miles. Mechanic (assume he is biased) thinks it is a head gasket. I think it's likely worse. It's cheap, not cheap enough to walk away from if the engine is toast, I would have to fix it somehow.
120,000 miles on the car.
I think it's too risky. Anyone disagree?
Old 06-08-2017, 08:33 AM
The Cardinals have elected a new pope?
Old 06-08-2017, 08:42 AM
GWN7's Avatar
Cheap enough to drop a 5.7 in it?
Bunch of old cars
Old 06-08-2017, 08:54 AM
I have no time for the 5.7 option. I am working 'out of country'. Even the head gasket is a stretch for me right now.
Old 06-08-2017, 08:59 AM
The Unsettler
stomachmonkey's Avatar
If you decide to pass maybe pass on the lead here?
I might be motivated to do a drop and swap.
"I want my two dollars"
"Brandon Won"
Old 06-08-2017, 09:36 AM
Slackerous Maximus
HardDrive's Avatar
Can't a bad air/oil separator also cause the same symptom?
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 06-08-2017, 09:43 AM
The car is in Canada...no problem sharing it I pass on it.
Old 06-08-2017, 10:13 AM
Seller says white smoke on one side, smells like coolant. He seems like a straight shooter. I think we can assume it's the gasket. Or worse.
Anyone here done one?
Car is about $7k US Funds. 1999 Cab, six speed, hard top, ugly green...
Old 06-08-2017, 10:23 AM
I'm totally ignorant of Porsche's water cooled engines since I'm an air cooled guy and I attempted to find an engine schematic for the 996 prior to posting, however, couldn't find one clear enough for me to understand. But with that being said, if this was an American water cooled engine, there could be a crack in the head, as well.
Old 06-08-2017, 10:36 AM
The more I look the less I think I should do it.
Heads crack, some can be fixed, some can't. Sleeves crack or shift.
Too risky.
Digging into this actually makes me reconsider the 996 idea completely.
Old 06-08-2017, 10:44 AM
The Unsettler
Thanks, not a Cab guy.
Too bad.
"Brandon Won"
Old 06-08-2017, 10:56 AM
Now in 993 land ...
aigel's Avatar
These deals are usually not good enough to cover your repairs. I.e. 10k for a car with a bad engine that would be 16k in good shape. It will be wiser to shop for a well priced car that works, IMHO.
And I am with you on 996s. Every time I start getting excited about a good deal out there I start reading but then get scared, haha!
G
81 SC (sold)
Old 06-08-2017, 11:00 AM
fastfredracing's Avatar
I went through this with my $5k 996. Fixing it just did not pen out , no matter what route I went. I was going in way deeper than the car was worth. If it is just a cracked head, or gasket, and you diy, you may win, but if a sleeve slipped, or d chunked, you loose .
Mine was d chunked and I just did not love the car enough to go that long on it. Sent it down the road .
No left turn un stoned
Old 06-08-2017, 02:17 PM
You do not have permissi
john70t's Avatar
Toss in a can 'of rubber mouse turds(Bars Leak).
If that don't work, toss in five more.
[/sarcasm]
Old 06-08-2017, 06:30 PM
Banned
Do a compression check. If its ok, probably a bad air oil separator. Bit of a pain to change on a 996 without dropping the engine.
Old 06-08-2017, 06:59 PM
944 S2
944 S2's Avatar
There's a reason they tell you to buy the best Porsche you can afford! Unknown repairs can be scary expensive.
Ya know you'd never have that specific problem with an air cooled 911! : )
Old 06-08-2017, 07:11 PM
Did you get the memo?
onewhippedpuppy's Avatar
Bad bad idea. Could be way worse, and you don't have time to deal with the best case scenario. These cars don't have huge upside unless you get it for free. Walk away, it's not worth it.
‘07 Mazda RX8-8
Old 06-08-2017, 08:03 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
If its a head gasket, you can check for intermix in the oil/coolant. AOS will cause smoke as well as oil being to full, etc. but unless you know for sure, could be an expensive mistake. Those things are easy to fix though.
Marc
Old 06-08-2017, 09:04 PM
JavaBrewer's Avatar
AOS will mess with the MAF and render the car a stuttering Christmas tree warning light nightmare. That said I agree with those with experience and say walk away.
Old 06-08-2017, 10:11 PM
Banned
speeder's Avatar
Yuk. Not a desirable car and a loser even w/o all cards shown.
Old 06-08-2017, 11:19 PM
