cycling has-been
Soft Gel Caps
Can I slice a 1000 IU gel cap in half and expect to end up with two equal halves containing 500 IU each?
...or they filled with a liquid/gel that will run out when I slice? Thanks in advance, Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Targa, Panamera Turbo
freeze it first
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
I suspect they are filled with something that will run out unless you freeze it first like MD says. Of course, you then may need to worry about the half that you don't take immediately.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Now in 993 land ...
Take it every 2 days ...
Freezing may not be good for the contents.
Some are filled with liquid, some aren't. You'll need to know what's in it
Now in 993 land ...
Oh, also, why not cut one open and find out?
1k IU (i assume vitamin D) is about the base unit. Example: If you take 2k and think you need 2.5k, I'd just go to 3k or 2k, difference will be minimal. If you are really anal, then do like I said and take 2 one day and 3 the other. G |
also keep in mind you only absorb between 5-7% if taken orally
I, personally, are fine with 5-7%. Other than 100% the other way.
