Helicopter tape. Good, but expensive.
I buy clear wrap by the sq ft on ebay and cut it to suit my various bikes. I live on a gravel road, so put a bit on each bike behind the front tire.
The clear plasti-coat works well.
We use 2" wide heavy grade electrical tape. It peels off pretty clean, a little wipe with an adhesive remover takes care of the residue. It's thick and really does a decent job protecting the paint. The only disadvantage is that the adhesive goes a little soft in the heat. So if you leave it parked in the sun in the summer, it might lose adhesion. angela |
Clear plasti dip, trick is several coats and make it thick, then it peels off easy in one piece. https://www.youtube.com/watch?v=NNurBZVAbWI |
Xpel! The shop I was at wrapped a lot of cars with this. Usually just the standard front but also whole cars. The stuff is heat activated so it self heals. You can even buff it.
http://forums.pelicanparts.com/uploa...1500180477.JPG |
| All times are GMT -8. The time now is 01:20 PM. |
