Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by VincentVega View Post
Fill it up and pressurize, you'll see where its leaking if its external.
Nail the problem source, as mentioned.
Change the thermostat. It can stick closed and overheat, venting coolant. Even if ok, I would change for general PM reasons.
Also find if there is an air bleed port.
Clogged radiator
Packed fins
Thermostat
Water pump
Leak
Not much left unless some cam/crank sensor/timing issue and that would spit a code.
1981 911SC Targa
Old 08-15-2017, 02:29 PM
