Banned
miss using 18vdc power tool batterys
why because I have them, Li power tool batterys
used on a 12v rated El-bike and a 24v lawnmower batterys are ryobi 18v 4amp Li both the bike and the mower run hot on 18v and heat the battery and wires both came with lead acid 12v batterys [mower used 2 batterys] RATED AT 20 AMPS EACH original lead/acid battery are DEAD and NEW replacements are HEAVY+cost new Li batterys are costly at hundreds of $$$ each in the proper volts+amps so I am trying to make the 18v 4 amp units I have work would doubling the 18v Li batterys help them run cooler ? to have 1/2 the current from each at 18v so 1/2 the draw current flow ? will that affect the ''protection circuits'' in the power tool batterys ? I have used the mower on 18v and the motor and wires are fine / not hot but the batterys get hot say 140 deg f by the time they are used up mower cuts and works ok but sometimes the battery gets so hot the thermal protection circuit cut out and I have to wait while it cools or switch batterys the El bike I tryed last nite quickly over heated both the battery and melted my too small wires so the ride was short when I tryed the bike last nite but worked ok up to the point the battery quit [too hot] plan is up size the wires and reduce the draw by using two batterys in parallel to have 1/2 the current from each battery btw the bike has a connector with one round 1/8'' post and a triangle slot also about 1/8'' anyone know where to get one to match needs a triangle post and a round hole Last edited by nota; 09-25-2017 at 12:07 PM.. |
if you are asking if wiring the 2 18v batteries in parallel will make there life easier by reducing the current draw in half then the answer is definitely yes.
The batteries you have are probably in the range or 1-2 amp hours so 2-4 amp hours if wired in parallel. I assume you mean that the lead acid batteries are 20 amp hours rated so you would only have a small portion of the original capacity. Li-ion batteries have very low internal resistance and are capable of high burst currents. I suspect your bigger problem is the 1.5 times nominal voltage. The current draw is going up by at least a similar factor, and power is going up 1.5^2. I think with the much reduced capacity and the increased current draw you probably won't get good results.
84 930 07 Exige S |
Banned
yes the lead acid 12v battery was rated 20 amp/hours
the 18v Li are rated 4 amp/hours each but very lite so better for a bike range was claim to 25 miles at 20 amps on the el-bike so if I can get 8 miles out of 8 amps I will be happy as the stores are only a mile or two away over volts is not a big problem as it = more power and both the mower was free and the El-bike was cheap so no big deal if they burn up Li battery's I am a bit more concerned about as they are also tool battery and I would like to use them for some time SO will hooking two 18v Li batterys in parallel affect the ''protection circuits'' built into the battery? is the connector a common motorcycle battery connection ? with round and triangle plugs ? |
The battery protection circuits should keep you from outright killing them. They may accelerate their normal natural degradation with continued high draw use. But in general they will not let themselves over discharge or over temp even when hooked in parallel. If you want to be extra careful I guess you could put a very big diode in series with each. I don't think that it is required however, I just wouldent hook a fully charged battery to a fully depleated one.
I think the range will not scale linearly with capacity because of the increased current draw as discussed. Also 4 amp hours is a big Li-on battery. The cells they use are generally less than 2 amp hours so if they are the connected 4 series (~16 Vish nominal) 2 parallel, they will have 8 cells total and probably have significantly less than 4 amp * hours per battery. The manufactures are optimistic with their marketing of these things sometimes. There are some fascinating you tube channels where they test rated vs actual (see the you tube channel aVe, my favorite internet channel)
84 930 07 Exige S |
Banned
yes I understand the Li deal with under/over charged cells
and the need for balance in charges |
Platinum Member
Use Hobby batteries. Cheap, universal charger. 3s = 12v, 6s=24v
https://hobbyking.com/en_us/batteries/lipo-batteries-all-brands.html I would not put the ryobi batteries in parallel, they will not discharge evenly and may generate large currents internally trying to charge each other.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
People run and even charge hobby batteries in parrellel all the time, it is fine. These are the lithium polymer packs as sudgested from hobbyking. The liFe round cells in tools are significantly more tolerant of abuse and in general a bit safer.
Banned
doable as that would be part of the wiring on the unit not the battery but if both full charged why should cross charging happen they auto cutoff to prevent low volts [when the cross charging may happen] worse case a bike or lawnmower it is not a big fire problem batterys removed when stored or to recharge as they have other uses and are likely low when use is over in the bike or mower I like the ideal of multi use/roll batterys and trying to make these 18 volt battery's I have work |
Platinum Member
Using 18v battery on 24v mower shouldn't hurt either, will just spin slower.
18v battery on 12v bike could hurt bike (50% overvoltage) Do you know how much current bike draws under full load? If it is under 5 amp, something like this would work: https://smile.amazon.com/DROK-Waterproof-Synchronous-Converter-Adjustable/dp/B00CGSHR2S/ref=sr_1_1?ie=UTF8&qid=1506392433&sr=8-1&keywords=18v%2Bto%2B24%2Bv&th=1
Bike is likely in the 200 to 500 W peak motor range, so maybe as high as 50 amps at startup
Banned
320w for two 160w motors at 12v dc one on each end of the shaft
any body know where to get the plug with a round 1/8'' and a triangle 1/8'' pins ? one male one female on each side similar plug with 2 round pins is called an SAE connector used on trailers but of course my unit has a triangle pin+a round pin like a banana pin Last edited by nota; 09-26-2017 at 11:28 AM.. |
Banned
Banned
so 18v Li [really 20v full charged to about 15v cutoff] should be fine should be 320 watts at 12v =26+amps , but at 18v = under 20 amps |
10 gauge should be fine, pedal assist will reduce the current draw in any case. Current is proportional to torque for a motor
If you increase the voltage to the motor, it will not decrease the current. It will go up by approximately in proportion. The power rating is a nominal type rating. IF it is producing 320W at 12v (12x26 amps) it will produce around 720w (18X40amps) at 18 volts. THis is for the full throttle condition as Im sure there is some sort of throttle voltage control. 720W is of course over the power rating of the motor which is why it could release its magic smoke if ran at full load continuously It is common to reduce current by increasing voltage but this requires a different motor or a lower gear to reduce torque load.
84 930 07 Exige S |
Banned
only if the motor runs twice as fast producing double the power
at 12v X 26+a = 320w then the standard same work holds 320w divided by 18v = 16+ amps by the way I learned el-tricks I think/guess it will draw a bit more and run a bit faster but no where near 40a maybe near 20 amps |
The current is proportional to the torque and the speed is proportional to the voltage. So how the motor reacts depends on how it is loaded. The current of the motor isnt from the rpm its from the torque, but the increased voltage allows for increased current to flow (ohms law more or less). All this is going through a throttle control, depending on the motor and controller type (likely brushed dc), so if you have 18v going to the controller (which may fry it btw) at part throttle you can have substantially less at the motor.
However under full throttle full load if you double the voltage to the motor you will double the current and ~quadruple the power. You are also accelerating at 2x baseline by conservation of energy. Nominally at least, in reality it is worse because the motor is outside of spec and loses efficiency and basically turns into a heater. 320 watt rating is a completely nominal rating for the motor based on the company's confidence in it to produce power without blowing up. IF you put 100vdc into it and run it into a stall it will dissipate a few kilowatts as heat for a few seconds before it burns out. Not trying to be argumentative on this, but backing out current from the power rating is the result of a fundamental missunderstanding of how motors work.
84 930 07 Exige S |
Banned
this unit is pure on off
control is a micro switch to a relay in the battery box so full speed or nothing a golf cart type pulse speed control may be needed will see the Li tool battery do fit snug in the battery box I do appreciate you advice as most of my DC knowledge is 60's el shop and racing slot cars I built motors for [from kit parts] still wild with silver wire and trick bits cost was about the same as a real car junker but running back then I have been reading a bit on the Li battery lots of fear and BS on them on the net but the boat and golfcart guy's like them |
No worries. Since you just have a relay for simple control, things will be pretty easy on this side. This is one of those things where you may have to test how it works without worrying to much about the theory. You can try a couple brief "ons" to see if anything gets too hot. People are justified being a bit afraid of unprotected LI-polymer batteries, however tool batteries with their protections circuits intact are substantially smaller risk.
Here is how I would probably aproach: Start by wiring the motors is series and the batteries in parallel. I assume that the motors are typically in parallel for the 12v lead acid implementation. In series they will effectivly only see 9v each, so the performance will be much reduced. However lithium batteries have much lower internal resistance so it may not be as bad as you think. Drive around the neighborhood a bit like that and if you get ok performance, and milage, switch the motors back to parrellel and test again. I suspect this will work ok performance should be good, but things may get hot (some risk of letting the magic electronic smoke out of the motors or the relay), range might be a bit poor as well. Or everything may work just dandy, stop periodically to check for eccesive heat or burning smell.
84 930 07 Exige S |
canna change law physics
Why not use replacement LiFePo4 batteries? There are drop in replacements for most SLA batteries.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Banned
the mower was free the bike very cheap I had the power tool batterys and charger a 20 amp Li battery is $230 I need 3 + a special charger so spend almost a grand on batterys and a charger vs use what I have ![]() plus I like messing with stuff and the idea of reuse of stuff I have without just buying more stuff Last edited by nota; 09-28-2017 at 04:27 AM.. |
