Zink Racer
Can I safely modify this ladder?
I bought this podium ladder at Home Depot on line to use in my shop. I was between the 14ft and 12ft reach versions. Of course this one is too tall by a foot. The next size down would be too short (I think) . My shop ceiling is 14 feet and this one puts my head too close.
Can I safely cut 1 foot off of the ladder to customize the length assuming I can re attach the feet?
My other option is to return it and try the 12 ft. reach version but I do think 2 ft. shorter is too short.
Of course these are on line only.
Jerry
983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4
Old 09-29-2017, 06:20 PM
Whoopsies I was banned!!!
Esel Mann's Avatar
There should be a way to check height specs under the product spec tab. You may need to go to the manuf. site if home repo doesn't have the specs.
Old 09-29-2017, 06:45 PM
A930Rocket's Avatar
Not sure about that ladder, but I once had an extension ladder that was too tall and I had to cut the legs off so it wouldn't rest on the glass of a window. Got my mitre box out and cut a foot off each leg. Worked like a charm.
Old 09-29-2017, 06:54 PM
John Rogers's Avatar
If you decide to cut it, do it at the bottom and make sure the bottom angles are all exact. I would then brace the "new bottom" with the same braces and such as original then have a friend try it out without telling him/her what you did (if your home owners insurance covers it). May not if they find out it was modified.
Old 09-29-2017, 07:01 PM
Fiberglass uprights?
I would think it might be OK, but if it ever came down to a lawyer because someone was injured and you'd probably be screwed.
Certainly don't tell them that I told you that it would be fine. I didn't even sleep at a Holiday Inn Express last night!
Old 09-29-2017, 07:20 PM
wdfifteen's Avatar
First thing I would do is try the 12' to be SURE you can't use it. Cutting that down re-drilling and re-riveting the feet and the braces is going to be a pain.
Old 09-29-2017, 07:45 PM
The Unsettler
stomachmonkey's Avatar
Fiberglass?
I own one, I will not buy another.
Steel is real, fiberglass can kiss my ass.
Yes, i just made that up and yes it is terrible but I have my reasons.
"I want my two dollars"
"Brandon Won"
Old 09-29-2017, 08:42 PM
wdfifteen's Avatar
Steel? Metal ladders of that size are usually aluminum.
But nothing rhymes with "aluminum"
Old 09-29-2017, 09:31 PM
Kantry Member
oldE's Avatar
How about "condominium "?
I'm surprised no one has suggested you rebuild the garage to raise the ceiling.
Seriously though, I would have just modified it long before I came here.
Best
Les
Best
Les
Old 09-30-2017, 03:28 AM
Platinum Member
dad911's Avatar
If it was personal, used only by me, I would modify it. For my company, or employees the liability is too great.
I would have employees rent or buy tools before I brought in tools from home. Too many examples of employers being held personally responsible for employee f-ups and carelessness.
Buy the shorter one, and a pair of platform shoes?
Old 09-30-2017, 08:22 AM
Esel Mann's Avatar
I'm of your thought, select the proper tool for the job. However this thread clearly has a strong 'best contender for Macgyver of the year' headwind that is growing
To that, presuming the OP were to ensure those gusset thingies of the first rungs (plus feet) were transferred to the new first rung, what if screws plus nylock nuts were used in place of the rivets to avoid any possible issues with home/hand rivet and riveting quality?
Old 09-30-2017, 08:36 AM
motion's Avatar
If this was me, I would cut off the legs. I would cut too much off, of course. Then, I would find an Amazon box and set the ladder on the box and climb up it to do the job. Then, I would haul the ladder to the dumpster with a smug look.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 09-30-2017, 08:48 AM
How tall are you? The ladder in your picture has the platform at ten feet, give or take an inch or two. (Known as ten foot podium ladder.) Next size down would have the platform at eight feet, which would put a six foot tall man bumping his head on a fourteen foot ceiling.
Old 09-30-2017, 09:04 AM
Zink Racer
I'm going to cut it. The platform on mine is at 8. I played around with it today and two feet down and it is too short to effectively get to my ceiling and top of the walls. Right now it is a foot to tall. They don't make a 7 foot podium. I might need to buy some new tools to do a good job on this :-)
Jerry
Old 09-30-2017, 02:25 PM
Naw...cut 1' off in the middle of each leg, butt them together and a couple wraps of duct tape... done! Much easier, and perfectly safe to do the modification this way imo.
But I wouldn't use it
Maybe not....ask Dipso...
Old 09-30-2017, 03:03 PM
Would it be feasible to move the platform down one rung? Can't tell from the photo but drilling and rerevitting might be easier.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-30-2017, 05:05 PM
wdfifteen's Avatar
I'm kind of cowardly about these things. If I absolutely HAD to have a 13 foot ladder I would start with a 12 and build leg extensions. Prolly cut 4 one-foot pices of 2x4 and 4 three foot pieces. Sister a short piece flush on the end to each long piece with bolts, then bolt one of these to each ladder leg, with the leg resting on the one-foot piece and bolts attaching the remaining two-foot section to the outsides of the ladder legs. It's cheap and Way faster than cutting a long ladder down.
Old 09-30-2017, 06:31 PM
Send it back, pick up a used scissor lift on Craigslist.
Old 10-01-2017, 09:59 AM
To answer the question in the OP, yes theoretically. In fact Warner ladders has you cut the first run off an extension ladder to install their ladder levelers...
If you do it just take your time and reinstall all the little braces and make sure there's no wobble.
Old 10-01-2017, 10:11 AM
