enzo1's Avatar
What about the coil? Mine idles fine ...
76' 911s Signature Edition
Old 11-05-2017, 09:42 AM
Brew Master
cabmandone's Avatar
Try running it with the choke half on and see if it straightens out.
Old 11-05-2017, 09:43 AM
Brew Master
cabmandone's Avatar
If it starts and idles fine but dies or almost dies when you give it fuel, I'm going with a fuel issue like a partially blocked main jet. As you're opening the throttle you're getting more air than fuel and going lean to a point where the engine dies or almost dies.
Old 11-05-2017, 09:46 AM
Still Doin Time
asphaltgambler's Avatar
My experience: All of the remaining 2-stroke powered equipment being sold today are being tuned 'lean' from the factory to reduce emissions and smoke. That little carb has plastic 'limiters' on the mixture adjusting screws / low and high speed fuel circuits. Typically only allowing @1/2 turn either way.
They are installed by the factory to prevent 'Joe Consumer' from 'adjusting' the mixture out of range to the point of not running.
You are running lean on both. You'll need to first carefully turn counter-clockwise the low speed fuel mixture screw to the limit / limiter range. See if that cures the problem, because that is where you need it somewhat 'fat' when idling - so when you hit the throttle, the cylinder is loaded properly with fuel to accelerate as there is no accelerator pump shot.
If the mixture does not 'fatten' up enough - you can force it gently further by continued turning further which will break the limiter cap to get into the range you need.
Those screws should be clearly marked 'Lo' and 'Hi" - also do not confuse those with the idle speed screw which is a separate adjustment that does not have a limiter cap.
Any happy 2-stroke should emit a nice rolling, 'gurgling' sound at idle. Then instantly RPM when the throttle is hit WO. When held WOT and no load - there should also be a slight 'gurgling' that cleans up when a load is placed. If not, you'll need to adjust the 'Hi' speed mixture screw in the same way.
PM me with any questions past answered here if need be.
Old 11-05-2017, 10:04 AM
Bill Douglas's Avatar
Yes, it's these I mentioned on my earlier post. The Husky people were trying to get it running to factory, low emission, spec's that just didn't work. I just turned them until it rev'ed like a, well like a small two stroke engine should.
Old 11-05-2017, 10:11 AM
wdfifteen's Avatar
Also replaced filter in tank and lines ...its something else
Did you change the fuel tank vent? Try running it with the fuel cap loose.
Old 11-05-2017, 10:33 AM
Model Citizen
herr_oberst's Avatar
Make sure you replace all the fuel lines with alcohol/ethanol resistant hose while you're at it. Cheap insurance.
Old 11-05-2017, 11:07 AM
Information Overloader
2-stroke engines smoke, even when the fuel is mixed correctly. That means exhaust gasses and particles get, well, exhausted through the spark arrestor as is on most 2-stroke engines on yardequipment. So when you throttle up the combusted air/smoke cannot exit and the engine acts like it's not getting air when actually it is not exhausting it.
After checking fuel lines, gaskets, spark plug, carb, air/fuel adjustments, pure gas, blah blah blah and it still acts like it's starving for air------clean the arrestor.
Or clean it first and avoid doing all that other stuff.
If it still doesn't work, give it to your son-in-law to mess with and then throw out eventually.
Old 11-05-2017, 11:12 AM
DanielDudley's Avatar
Dump out your tank and start with all new fuel mix, fresh this week. Try running it without the air filter. Those new Stihl filters are made to clog. they won't blow out like the old ones would.
Old 11-05-2017, 11:41 AM
Mine was doing that. I took the carb apart and cleaned it up. Works fine now. I saw some yellowish looking build up in it from the crappy fuel we have now.
Old 11-06-2017, 08:21 AM
Brew Master
cabmandone's Avatar
Turns out my brother was working on his friend's older Stihl BP blower that was having a similar issue. He cleaned the carb and adjusted and the thing ran fine for him but when his friend got it home it would run fine for a while and then start bogging down. His friend ended up buying a new blower. I almost wonder now if it might not be a coil issue were when it warms up from running it isn't losing resistance in the coil due to heat and then cutting out or not firing right?
I still think I'd try running it with the choke partly closed when it starts acting up to see if it clears. If it does clear that would indicate a lean situation meaning a plugged jet somewhere in the carb.
Old 11-07-2017, 06:42 AM
I see you
flatbutt's Avatar
New carb on order.
Old 11-09-2017, 02:36 PM
MBAtarga's Avatar
When my Echo blower acts up and bogs down like your symptom a brand new fuel filter has fixed the issue.
Sent from my iPhone using Tapatalk Pro
Mark
'83 SC Targa - since 5/5/2001
Old 11-09-2017, 04:01 PM
Brew Master
cabmandone's Avatar
Keep us posted! I hope the new carb fixes it for you. I'm looking into buying some adjustment tools for my Husqvarna chainsaw, leaf blower and trimmer
Old 11-09-2017, 04:24 PM
I see you
flatbutt's Avatar
Tks MB that was the first thing I checked, well the air filter first then the FF. Then following advice here I spent some time with the L and H screws but that didn't do anything. So I pulled the gas tank and the lines were "OK" but not great. Went on to the carb and found it to be ...well not to get too technical but it didn't look so very freakin' good. Ran over to my local chainsaw guy and he said the diaphragm was shot.
He also said that it looked like I had used old gas, which I had. He says that even if treated gasohol shouldn't be used if it's more than a month old. huh I didn't know that.
Old 11-09-2017, 04:33 PM
