| Registered |
				Knife sharpening: wood block
			Knife sharpening experts, would the typical knife sharpening motion and angle, on a wood block, A) sharpen the knife B) dull the knife C) no change ? Thanks, | ||
|  11-19-2017, 05:07 PM |
| Registered Join Date: Mar 2004 Location: Los Angeles
			Wut?
|  11-19-2017, 06:46 PM |
| Registered Join Date: Jul 2008 Location: OK
			You mean like using a leather strop? but with wood?...
				__________________ 76' 911s Signature Edition | ||
|  11-19-2017, 06:54 PM |
| Registered Join Date: Jun 2002 Location: Winnipeg, MB, Canada
			I think maybe pulling the knife out of a wood block?
				__________________ Bunch of old cars   | ||
|  11-19-2017, 07:16 PM |
|  11-19-2017, 07:25 PM |
| Registered Join Date: Jun 2017 Location: Michigan
			Is this like the airplane on a conveyor belt question?
|  11-19-2017, 07:34 PM |
| Registered Join Date: Nov 2000 Location: AZ
				 | Quote:
 Northern or Southern hemisphere? African or European wood? Wind speed and direction?   | ||
|  11-19-2017, 08:19 PM |
| Registered |
			I put my knives in the wood block upside down. Blade edge up.
|  11-19-2017, 09:31 PM |
| Registered Join Date: Jan 2007
			I once carved a set of hearts from a piece of walnut, using a Stanley 199 utility knife with the replaceable blades. I took only light cuts. The blade was virtually as sharp when I was done as it was when I started. Most wood will neither dull nor sharpen a blade, as long as you do not deform the absolute edge.
|  11-20-2017, 12:26 AM |
| Registered |
			I suspect wood will always dull the blade. I've built a lot of architectural models using soft woods like balsa and bass, they most certainly do dull blades, but I'm cutting not trying to sharpen them on the flat side. I'm going to have to research this to validate, but my current theory is that the coefficient of friction on a leather strap, and the way it conducts or absorbs heat is different than that of wood. That the friction and heat are in such short time periods that your senses don't pick up on it don't mean that they are not there. Sort of like a needle running through the groves in a vinyl record. The friction and heat melting the vinyl for a micro-second thereby insuring each time you play the record it will sound every so slightly different and eventually wear out. Your senses simply cannot pick up on this. One could conduct an experiment flat side rubbing a knife on leather and then wood to see which material transfers heat into the knife or transfers the heat into the the wood or leather. Can I change my answer? I just found this: Razor strop https://en.wikipedia.org/wiki/Razor_strop Quote:
 That is my answer, but I could change my mind a couple of more times.
				__________________ 1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 11-20-2017 at 01:29 AM.. | ||
|  11-20-2017, 01:27 AM |
| Guest
					Posts: n/a
|  11-20-2017, 05:23 AM |
| You do not have permissi Join Date: Aug 2001 Location: midwest
|  11-20-2017, 06:04 AM |
| Band. |
You forgot Laden or Unladen!
				__________________ 1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII | ||
|  11-20-2017, 06:07 AM |
| Registered |
			I use a Kapoosh knife block. All my knives are different sizes and manufacturers so it works great for me.  https://www.amazon.com/Kapoosh-Batonnet-Knife-Block-Woodgrain/dp/B005R21NQG/ref=sr_1_2?ie=UTF8&qid=1511195645&sr=8-2&keywords=kapoosh+universal+cutlery+block&dpID=417RjGSgHHL&preST=_SY300_QL70_&dpSrc=srch
				__________________ --------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain | ||
|  11-20-2017, 07:35 AM |
| Detached Member Join Date: May 2003 Location: southern California
			My wood knife block they go in sideways.
				__________________ Hugh | ||
|  11-20-2017, 08:30 AM |
| Registered | Quote:
 I use the knife to scrape stuff off the cutting board, into the pan or into the compost. Usually not hard scraping, just a gentle motion like you would with the leather strap. Thanks. | ||
|  11-20-2017, 09:06 AM |
| Registered |
			It dulls the edge. Similar move on a cutting board has the same effect.
				__________________ poof! gone | ||
|  11-20-2017, 02:46 PM |
| Registered | Quote:
 Get yourself one of these: https://www.amazon.com/dp/B000SSZ4Q4/ref=asc_df_B000SSZ4Q45276453/?tag=hyprod-20&creative=394997&creativeASIN=B000SSZ4Q4&linkCode=df0&hvadid=167142021489&hvpos=1o1&hvnetw=g&hvrand=13137805465145095932&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061081&hvtargid=pla-306143543904
				__________________ Bone stock 1974 911S Targa. 1972 914/4 Race Car | ||
|  11-21-2017, 07:43 AM |
