A930Rocket's Avatar
Are shower valves adjustable internally?
I’m wrapping up some new apartments and many people have complained about the low water temp in the shower.
I went to a random unit and took a digital thermometer and got 123* at the kitchen faucet and 101.8 at the spout/shower. The inspector says 120* max.
Same distance for both to the electric water heater.
How can there be a 20* difference?
I’ll find out the make and model of the shower valve tomorrow, but if I take the cover off, can the shower valve be adjusted to get more hot water out of it?
Any ideas from the great PPOT?
*** BTW, my plumber is worthless***
Old 01-03-2018, 03:44 PM
Platinum Member
dad911's Avatar
Yes. 'Hot' is limited. Usually by a stop under the trim that limits travel.
I would make plumber do it. You don't want the liability if someone gets scalded.
Old 01-03-2018, 03:53 PM
Banned
showers have a ghimic that limits the hot when another line is open so no burns
also hot water lines get clogged with lime deposits quicker as do shower heads
esp low flow newer heads
ether or both can limit total flow
new connections can stir up the deposits in the old water main sending gunk in to your new system
as they drill the old pipe [inside a sleeve] that shakes the pipe
Old 01-03-2018, 03:57 PM
Now in 993 land ...
aigel's Avatar
What kind of thermometer are you using?
81 SC (sold)
Old 01-03-2018, 05:23 PM
SoCal911T's Avatar
At least out here, those stops aren't for limiting travel. They're so you can shut off the water to a valve to service it without shutting off the water to an entire apartment building. They usually are frozen from lack of use but it's a good idea on paper.
Old 01-03-2018, 05:33 PM
Platinum Member
dad911's Avatar
No, not shutoffs. Diverter has an adjustment so water heater can be set to 130-140 and shower limited to 120.
Like this kohler:
Old 01-03-2018, 05:41 PM
Home of the Whopper
Yup. Recently adjusted mine to increase water temp at shower.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-03-2018, 06:06 PM
SoCal911T's Avatar
Yes, but two completely different things. All valves don't have temp adjusting feature.
Old 01-03-2018, 06:16 PM
A930Rocket's Avatar
It’s a cheapo digital thermometer from Amazon.
Old 01-03-2018, 06:23 PM
A930Rocket's Avatar
If there is an adjustable screw to change the water temp like that Kohler, it would be an easy fix. But then my plumber probably doesn’t want to adjust 152+ shower valves!
Old 01-03-2018, 06:37 PM
rfuerst911sc's Avatar
Every shower valve I have installed in the past 20 years has had an adjustable temp mechanism . Either a screw or a ring . That was for Delta and Moen .
Old 01-05-2018, 06:30 AM
A930Rocket's Avatar
We checked another unit and the plumber raised the temp to 118* by his digital thermometer. Plumbing inspector says 115*-120* max, which might not be hot enough for some people.
Old 01-05-2018, 09:49 AM
Platinum Member
dad911's Avatar
Inspector is correct. Don't set it higher.
www.asse-plumbing.org/WaterHeaterScaldHazards.pdf
Old 01-05-2018, 10:12 AM
