Any way to get oil out of a concrete garage floor?
Long story but I have an oil stain, well, more than a stain, on my garage floor from oil leaking from the "S" oil line from the 911 while we were away for several weeks, and then getting saturated into the concrete for another month or so. I finally move the car and saw the oil. I tried Oil-Dry, the kitty litter type stuff, and sprays. I let them all soak in and then used a power washer to hose it off. Some came out, but it still feels damp, sticky and oily. Any recommendations?
JUAN
'80SC Targa
Old 01-31-2018, 07:26 AM
least common denominator
scottmandue's Avatar
Engine de-greaser works pretty good.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 01-31-2018, 08:16 AM
The Unsettler
stomachmonkey's Avatar
No help now but this is why there is always several layers of flat cardboard under my cars.
"I want my two dollars"
"Brandon Won"
Old 01-31-2018, 08:23 AM
Cars & Coffee Killer
legion's Avatar
I like to put a puddle of water over the area and let it sit so that much of the oil floats to the top (you may have to construct a makeshift dam around the area).
Then degreaser.
5 liters of VVT fury now
-Chris
acar24's Avatar
oil slick
try the old type tide or cascade and whisk and hot water/ broom in. Good luck LA
Old 01-31-2018, 08:30 AM
Platinum Member
dad911's Avatar
oil eater
https://www.amazon.com/Oil-Eater-Original-Cleaner-Degreaser/dp/B000EALHH6/ref=sr_1_3?ie=UTF8&qid=1517416999&sr=8-3&keywords=oil+eater
Old 01-31-2018, 08:43 AM
Yeah, I have some grey absorbent pads under where i have a tiny drip, but this happened where it was previously dry. Now I have them under the entire engine. Thanks for the tips, I'll try them all and see what happens. I had the kitty litter type stuff on it for a few days. It adsorbed a fair amount, but the stuff that's deep in the floor it couldn't suck up. Well, I have a few things to try. Thanks
JUAN
'80SC Targa
Old 01-31-2018, 08:50 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
A couple more ideas(?):
Concrete oil stains
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 01-31-2018, 08:55 AM
Takin' hard left turns
Amail's Avatar
I bought some Tri Sodium Phosphate (TSP) at Home Depot to get rid of an oil patch. I'd read when mixed with the oil it produces a kind of soap, which can then be scrubbed and rinsed away. I never actually tried it though, so I can't vouch for it, but it's something to look in to.
Old 01-31-2018, 09:06 AM
Halm's Avatar
Had some success with Oil Flow Solvent https://tinyurl.com/y9vnzq75
'17 Cayenne
Old 01-31-2018, 09:35 AM
Simple Green has worked for me..put it on full srength and let it set....on a driveway until the rain washes it away.
Old 01-31-2018, 09:46 AM
T77911S's Avatar
i use the cheap cat litter.
then I will either stand on it and do the "twist" back and forth or I have a wood block I use to grind the cat littler into the oil stain.
you can first try some brake clean then use the cat litter.
you have to grind it in to get it to clean.
there will always be a residual stain but nothing bad
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-31-2018, 09:47 AM
I also use the cheap car litter method, I let it sit after grinding it down.
As said it will dry up the spot but still leaves a stain.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 01-31-2018, 10:03 AM
enzo1's Avatar
CHEAP old style no clumping agent @ Dollar General cat litter....grind it in
76' 911s Signature Edition
Old 01-31-2018, 10:15 AM
Dry cement powder works extremely well. Sprinkle it over, leave fro a day or two, then sweep up. Much more effective than kitty litter.
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 01-31-2018, 10:54 AM
I have some TSP, so I'll try that. I did the kitty litter dance several times, it helped some, but I can tell it's done all it can do. It's 27 degrees today, should get up to 42 tomorrow, so I'll try again tomorrow. If the TSP doesn't work, I'll try the other recommendations. Thanks again
JUAN
'80SC Targa
Old 01-31-2018, 11:17 AM
Amail's Avatar
Cool - let us know how it works.
Old 01-31-2018, 11:20 AM
The Stick
RKDinOKC's Avatar
Just coat the entire floor with oil. Let it set. Clean up using oil-dray or cat litter and call it good. The whole floor will be stained so it will look fine.
Richard aka "The Stick"
06 Cayenne S Titanium Edition
Old 01-31-2018, 11:21 AM
T77911S's Avatar
Just coat the entire floor with oil. .
I have done that already.
never fails. I seem to dump at least a qt when I open oil lines.
just pulled the valve body off the Mercedes, about a half qt missed the oil pan
RACE CAR:: sold
Old 01-31-2018, 11:28 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Sundek pal of mine is at my shop. Says that you are not going to get the stain out completely.
Time and multiple cleanings.
Interesting comment he made. Said moisture vapor transmission from below (depending on what's underneath the slab) can help degrade the stain over time. Not what you want for an epoxy coating but can assist in purging the poisons.
Absolutely no on muratic acid. Cleans well then you have a porous clean slate for any cooties that come along.
1981 911SC Targa
Old 01-31-2018, 11:34 AM
