-   -   Volvo xc70 engine is toast -- Replace engine or buy new car? (http://forums.pelicanparts.com/off-topic-discussions/990582-volvo-xc70-engine-toast-replace-engine-buy-new-car.html)
95avblm3 04-22-2018 11:10 PM
If it hasn't been done, do your air/oil separator/PCV/whatever Volvo calls it now while its apart and easy to get too. Ours started running poorly (very suddenly) to the point it wouldn't idle. I bought the kit from one of the Volvo parts house and replaced it all... I think it was ~$250 in parts. It solved the problem. When I got the AOS off the car, it was completely blocked with carbon sludge.
T77911S 04-24-2018 03:52 AM
i am surprised the engine lasted longer than the tranny...don't get me wrong, love(D) Volvos.
LEAKYSEALS951 04-24-2018 04:02 AM
You and me both. I have changed the transmission fluid 3 or four times since new, with the first change at 80k, and changes every 30 since. From 120k to 200k it downshifted like dog. On the last change, I added a magline filter on the cool side oil return tube, and it has shifted progressively better ever since. It now shifts like a new car.
Also, on the last change, I set the oil level while the engine was "hot" instead of using the "cool" level on the dipstick. That made a HUGE difference.
Although I haven't pulled the turbo yet, I was making a parts list this morning. I'm not looking forward to pulling the turbo and displaying the trashed inside to you guys this weekend.
Researching gaskets- Are Victor Heinz gaskets worth a darn? They are all over ebay.
Also Stigan turbos- any info on those? The volkswagon reviews of them seem to be all ok.
Are there any aftermarket brands to avoid/ or pay more for in this area- like avoiding brazilian bosch coils?
Thoughts? tia- ron
Steve Carlton 04-24-2018 07:30 AM
Interesting info on the magline filter, Ron. I'm asking my service manager about that and what turbo and gaskets to recommend.
Steve Carlton 04-24-2018 07:51 AM
He said he has our turbos rebuilt, as long as your housing isn't trashed. Possible the chunk from your valve is stuck in the gunk in the exhaust manifold, but that looks like a big chunk, so maybe not. Big yes on the PCV stuff, and probably all your hoses will need replacing.
beepbeep 04-24-2018 02:30 PM
I believe only certain Aisins had issues? The switch was some time around 05 I think.
My FIL has 02 with tranny that has been flaring on 2:nd to 3:rd shift for last 10 years...it hasn't got any worse though.
LEAKYSEALS951 04-24-2018 03:44 PM
Thanks for checking Steve. It will be interesting to pull it this weekend and see the damage. I remember when you and I spoke about the car over 2 years ago and were talking about how the transmission could go at any second. I'm certainly not tempting fate. The second I get cocky about it, I'm sure it will go :)
LEAKYSEALS951 05-01-2018 07:06 AM
I think I lucked out. Pulled the turbo today. No real exhaust fan damage from broken valve. ZERO play in shaft. Lightyears better than my 951 turbo shaft play.
In honor of retrieving this undamaged turbo, I broke off an exhaust stud for good measure. Since I own a 911 with original dilivar studs, I should know how to get that out , but I've never had the pleasure yet.
I'm assuming some new seals and I'll be good to go?
(edit- UPS guy still hasn't picked up my box of awesomeness containing the head to be rebuilt. Wife's dogs are whining to get out to go pee. I can guarantee the second I let them out, UPS guy will come up driveway and dogs will eat him)
http://forums.pelicanparts.com/uploa...1525186068.JPG
LEAKYSEALS951 05-08-2018 03:10 AM
UPDATE-turbo rebuild and the REGAL TOUR X
I went and disassembled my turbo. After the initial euphoria of pulling it and seeing no damage, I realized there was some play in it, so I figured I'd rebuild it. Also, it was noisy after the valve broke, almost like a turbo whine on a cummins diesel. Like an idiot, I bought a cheap ebay rebuild kit, watched a youtube video, and realized the replacement bushings have more slop than the originals! I am also scared that without getting the thing balanced, it might not spin reliably for the long term. It was much louder after car broke valve- I am concerned shaft got bent ever so slightly. I am not concerned about the turbo itself (replacing/rebuilding), it is accessing it again if things go south.
I don't want to revisit getting to the turbo. It's a pia.
Second- I drove the new BUICK REGAL TOUR X. :) Overall- okay car. Lot's of space. Actually better looking in person than in pics. It's one of the few american cars I enjoy look at. Reminded me a little of 1970's wagons in it's length. Was not impressed with auto cut off feature (especially with a stressed 2liter turbo pumping out 250hp), lack of spare, and higher than expected wheel noise from rear of car. It had about $6k of unneeded bells and whistles that I want nothing to do with.
I like it, but 40K can buy a lot of stuff.
Hmmm....
So.... In terms of rebuilding a turbo, does anyone know where I can get the CHRA assembly rebuilt properly (and balanced)? Or just a new CHRA core? It's a mistibishi unit that they use on the volvo. I could buy all new, but that's a lot of parts and $ to fix a relatively small issue.
http://forums.pelicanparts.com/uploa...1525776422.JPG
slow&rusty 05-08-2018 03:51 AM
I've been in the exact same boat (right down to the chunk missing out of the valve) and although I consider myself a really solid shady tree mechanic, after I removed the head I took it to my favorite engine builder in town and he put 16 new valves, guides and seals and made sure the head was dead straight. This cost me $600-$700 and was definitely worth it.
Concurrently, I also replaced my turbo seeing that it was all apart with a freshly rebuilt one as the turbo rebuilder I use offer a great core exchange program with a 1-2 day turn around with a 12 month warranty. Plus the eBay Chinese kits are a disaster - be warned!
I hope that helps.
Yasin
Steve Carlton 05-08-2018 08:06 AM
Vargas Turbo Inc. - Home Page
LEAKYSEALS951 05-08-2018 12:57 PM
http://forums.pelicanparts.com/uploa...1525811915.JPG
Steve Carlton 05-08-2018 01:30 PM
Cool. Tell them Mike Mascote at McKevitt Volvo referred you. He's the service manager there.
I have moved on to greener pastures at Volvo Cars Walnut Creek...
LEAKYSEALS951 05-08-2018 01:37 PM
Will do. Thanks!
Ron
LEAKYSEALS951 09-02-2018 03:41 PM
As of 5:00 est Sept 1st, the volvo LIVES!!!! (subtitled- "That was a B#$~~!!!!") :)
<iframe width="560" height="315" src="https://www.youtube.com/embed/GFgVSeLb_Gk" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
(please ignore all lifter/ injector noise... it's really not that loud)
not that I care, I was just happy it spins and doesn't bend valves. A summer worth of bittersweet sweat and tears! It took me 30 seconds to get the guts to turn the ignition on.
http://forums.pelicanparts.com/uploa...1535930214.JPG
pavulon 09-02-2018 05:07 PM
Good on you for keeping a car you like and bringing it back to life!!
billybek 09-03-2018 04:57 AM
I have always liked those Volvo wagons.
Congrats on bringing it back to life.
slow&rusty 09-03-2018 05:17 AM
Congrats!
Steve Carlton 09-03-2018 08:20 AM
https://media.giphy.com/media/l3vRlI...NOow/giphy.gif
speeder 09-03-2018 09:18 AM
So what did it wind up being? I'm late to the thread but would have just sourced a good used turbo, they must be plentiful(?) Also, can't imagine living somewhere where you'd need to box up a common cylinder head and ship it off for a simple repair? You must be somewhere really remote. Machine shops are everywhere engines are.
The real mystery is how it could have 30 lbs. of compression, (held), w that sized hole in valve? That's a head-scratcher...should be zero.
I'm glad that you got it fixed. If I'd been on thread in the beginning, I would have told you to pull the head and fix it cheaply. One cylinder suddenly dead is in the head every time. I bought a Chevy PU a few years ago w a "bad engine" for cheap. Super clean 4x4 Silverado w the 5.7 Vortec, they generally run forever.
Of course when I pulled the valve cover, it had a broken valve spring and dropped a valve. The guy told me that he was driving down the highway when suddenly it bucked and started making horrible noises but limped to the side of the road. "What kind of noises?", I asked. "Like someone dumped the silverware drawer into the engine."
Thanks, buddy. That's all I needed to know. Pulled only the effected head and got one good used valve from a machine shop and one used valve spring+retainers. Lapped the used valve in. Old valve was bent and damage to top of piston was cosmetic and minimal. The engine only ran for a minute after event.
The point of the story is that I fixed it for the cost of a set of head gaskets, (still have the unused one), $10 for the used valve and spring and some of my own labor. It ran like showroom new and I drove it cross-country including towing a 911 I bought 2k miles on a U-Haul trailer home to CA. Still ran perfectly when I sold it a couple years later.
Cheap car= fix it cheap. What do you have to lose and w a little intelligence, you can put it back to where it was easily. Other than external wear items like belts and hoses, skip the "while you are in there BS" where guys make things worse than they were half the time. Look at those cylinders of yours @ 200k, they are like new. leave what the factory built alone where possible. :)
