Reloading shotshells
Since I’ve started shooting sporting clays I’ve notice a lot of the guys reload their shells. Since I reload my hangun shells I figure I might as well give it a try.
So I picked up this Ponsness Warren reloader that is set up for 12 and 28 ga. It cost about the same to reload as the cheap Walmart specials in 12 ga. But there is some savings in 28 ga, I just don't have a 28 ga. I guess I’ll have to either buy some tubes for my O/U, or a new spoon. Since I’m already set up to reload for it.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
Cars & Coffee Killer
I reload 12 gauge for skeet. I use Winchester AA shells and a MEC reloader.
I've been trying to get these to work: https://www.midwayusa.com/product/1657554245/magtech-shotshell-hulls-12-gauge-2-1-2-brass Using these dies on a single-stage press: https://www.midwayusa.com/product/296286/rcbs-cowboy-brass-shotshell-die-12-gauge
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Here are a few that I reloaded. I used Remington gun club hulls, clays powder, Winchester primer and wads. I didn’t take a pic of the rejects that I pitched while I was figuring out the crimp height.
Check out the CZ-usa imported side by side 28s ... They offer an O/U too I think but I've always thought that a 28ga should be a SxS CZ 28-Gauge Bobwhite Review - Guns & Ammo ![]() CZ-usa also offers a pump, "only" $400 should you wish to drop down to plebeian utility firearms https://www.budsgunshop.com/catalog/product_info.php/products_id/24864/Firearms/Shotguns/CZ-USA/Pump+Shotguns/CZ-USA+628+FIELD+SELECT+28+GAUGE |
Now you need to make your own shot. Seriously.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
That would definatly get the cost down. There is one guy that I shoot with that makes shot. Not sure what all is involved.
https://redlandsshootingpark.com/reclaimed-lead-shot-for-sale-shipment/ $65 for 50lbs delivered isn't much more than I paid for "virgin" shot back in the 80s.... $1/lb |
Then again, he used to go to a quarry and have people toss marbles for him to shoot with his Mini-14. No, he isn't Ad Topperwien.
(the shotguns)
I reload 28ga on a mec. Good stuff.
Do not buy tubes for your 12. Buy a proper scaled frame 28ga. Be warned however your other guns will gather dust. Sent from my iPhone using Tapatalk
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I thought about picking this up. I'm a fairly serious handgun and rifle reloader and bullet caster, and have been for over 40 years. Seems it would make sense to pick up shotshell reloading as well.
Well, I'm sorry to report, it just didn't make sense for me. I don't shoot enough shotgun, never having gotten into any of the clay bird games (although I've had just a yee-haw time on the occasions I have shot some). I really only shotgun to hunt. I don't go through but a few boxes of shells every year in total, and they vary from our mandated non-toxic for waterfowl and some upland on our West side, 3" mag #6's for eastside pheasant, 2 3/4" 7 1/2's for grouse, etc. I would be changing setups constantly to load a box or two of each. That, and I don't see the really "fun" part for us hopeless tinkerers and experimenters - shotgun reloading follows set "recipes", which removes the experimentation and fooling around inherent in metallic cartridge reloading. To met, that's the main reason I reload. I would reload even if it were more expensive than buying commercial. But, yeah, I can absolutely see it for you high-volume trap and skeet shooters. The thousands of rounds per year that you guys chew through would soon put you in the poorhouse without reloading. For a duffer like me, though, the ROI just isn't there.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Another problem is how to seal the end. Brass doesn't crimp like plastic. I bought 10 gauge overshot cards. The shells weren't building up enough pressure, so I tried gluing them in with Elmer's glue (saw a youtube video on this). Well, it tended to leak past the overshot card and glue the shot together. So then I tried pouring sodium silicate over the overshot cards. Because it has water in it, it tended to leak past the overshot card and build up next to the wad. Third attempt was using parafin. I haven't tested it yet. I do this because once I get it right, I'll have shells I can pretty much reload forever.
Almost Banned Once
- Peter |
