very compact sump pump needed
I need a small sump pump to drop into a tight sump in the yard. The previous owner told me he put the sump in to keep the water down during snow melt season. Its a very small sump. Maybe 2 feet deep, 8" inside diameter. At the top it necks a little, I don't think anything bigger than 7" would go in there.
Any recommendations for something I could use for a month or two? I looked for sump pumps but haven't found anything small enough to fit in there. I could put some kind of aquarium pump in there but I don't think anything small enough to fit will have enough juice to lift water out of the pit. Plus i would then need a way to control it.
Are there any sump pumps small enough in the world? Any suggestions on where to shop?
Old 03-27-2018, 06:58 PM
id10t's Avatar
Here ya go, a pond pump - dimensions are right and can pump to over 5 feet
https://www.lowes.com/pd/smartpond-300-Gph-Submersible-Fountain-Pump/50125821
However... don't think ti is what you want, unless you want to manually control when the pump pumps. I'd also be wary of picking stuff up in the intake...
Old 03-27-2018, 07:15 PM
Cajundaddy's Avatar
There is always one out there. How much water do you need to move? 115VAC? how high do you need to lift it? Does it need a float switch to run automatically? Lowes actually has a decent selection. If not what you want, check McMaster Carr.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Simer makes a complete line of sump pumps. Very reliable. I know Menards carries them..not sure about Home Depot.
Old 03-27-2018, 07:46 PM
Just thinking out loud
mattdavis11's Avatar
A bilge pump bailed me out more than once.
91 FJ80
84 Ram Charger (now gone)
Old 03-27-2018, 08:20 PM
yes, needs a float switch. 115 ac preferred. unknown how much water to expect. Cant be loads...
the sump is about 2 feet deep. I just need to get it to the surface and then ten feet to the top of a slope. Then it will be gone.
Old 03-27-2018, 08:47 PM
Cajundaddy's Avatar
This should work.
https://www.amazon.com/dp/B00502AIUU?ref=emc_b_5_t
Old 03-27-2018, 09:01 PM
wdfifteen's Avatar
You need a sewage ejection pump unless there is some kind of filter before the sump. Go big now or go big later, but you will go big.
Old 03-27-2018, 10:54 PM
enzo1's Avatar
I've got a Liberty, works good... Sump Pumps / Systems
76' 911s Signature Edition
Old 03-28-2018, 06:23 AM
Here is your float switch:
https://www.amazon.com/Piggyback-Switch-Septic-System-Sump/dp/B01BEHQVEQ/ref=pd_day0_60_1?_encoding=UTF8&pd_rd_i=B01BEHQVEQ&pd_rd_r=GBHBK9ST0FAXPS09M3N8&pd_rd_w=oljAY&pd_rd_wg=PF2AP&psc=1&refRID=GBHBK9ST0FAXPS09M3N8
Assuming you will be running 110v out to a small sump pump, this switch has a piggy back plug which you can use in conjunction with the plug on your pump, in order to control when it turns on and off - according to the float which you will have to tether inside your sump somehow.
Old 03-28-2018, 06:33 AM
Puny Bird
Mark Henry's Avatar
A cheap pool drain pump.
Then when the frost is out of the ground dig in a proper sump pit below the frost line, so the pump doesn't freeze and install a good sump pump. Then you don't have to fork around with it every spring.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 03-28-2018, 07:16 AM
