The anchor points are about 18' up. And I was trying to obtain a very natural (that word again) swinging motion.
So now, we're thinking about cutting and using one of those smaller trees in the left corner to use as a horizontal beam.
hey flipper i think we are hiring!! wanna job? :D |
A piece of pipe spanning the trees would work better. I'll let Cliff determine the size of the pipe needed. Then either drill it for some eyelets or weld some on at the desired spacing
You could also run 5/16" wire rope between the trees using Crosby clamps to secure it to itself once looped around the branches. Fit a rubber sleeve over the wire rope where it contacts the branches to prevent it from digging into the wood. Tension as necessary, and use (2) additional Crosbys on either side of each swing rope(total of (4) to keep the swing centered on the cable, use oversized washers between the swing hangers and Crosby to allow smooth movement, and use a carabineer to attach swing rope to wire rope.
OMG, I'm an engineer, and you guys are way over thinking this. Tie a rope to each tree, a tire in the middle, and let the kids have fun. If you really want a classic swing, connect a 4x4 to both trees and attach swing to it.
How much of a hill is there? It's best to swing out over the hill. Or tie a cable to a tree on the hill about 10' high, other end to the house or a lower tree, and attach a pulley to a T handle. |
Again, those trees are going to move a great deal when there is wind so any beam or pipe attachment will have to account for that movement.
Personally I would do a zip line also.
Wrapping anything around the trunk or a branch may, in time, kill the tree or the branch.... aka "girdling" (the tree's vascular system runs just inside the layer of bark). I might consider this, instead. Boring through the trunk of a tree will not kill the tree. It would be easy to try and you'd know quickly whether the tree could withstand the forces of unfettered swinging.
http://forums.pelicanparts.com/uploa...1522180628.jpg |
| All times are GMT -8. The time now is 05:00 PM. |
