-   -   Swing Project - Engineering Advice Needed (http://forums.pelicanparts.com/off-topic-discussions/991858-swing-project-engineering-advice-needed.html)
nota 03-27-2018 03:46 PM
hemp rope ROTS
Dacron will last many years
sand_man 03-27-2018 03:54 PM
^^^yeah, I had a feeling. I will post up my latest vision, later. A hybrid of sorts.
A930Rocket 03-27-2018 06:32 PM
This is what I did years ago with chains and trees that were much bigger and it had a lot of sag with me on it.
The kids did pretty good though.
http://forums.pelicanparts.com/uploa...1522164382.jpg
masraum 03-27-2018 07:32 PM
Cut down the trees, buy 2 telephone poles, a 10' section of telephone pole with the ends cut in a semi-circle(unless you want to go for some sort of joint which may be more secure), and get four 1" steel cable guy wires with anchors....
wdfifteen 03-27-2018 10:35 PM
Originally Posted by dad911 (Post 9978070)
OMG, I'm an engineer, and you guys are way over thinking this. Tie a rope to each tree, a tire in the middle, and let the kids have fun. .
You sir, are a fraud. Any real engineer worth his PE badge would indeed over think the project. Protection against Fire, flood, nuclear blast, nuclear fallout, EMP, and hurricane-force winds should all be designed around,
I would hang a 3" iron water pipe between the trees drop some ropes from it, and be done with it, but I'm a retired, no-longer-practicing engineer.
KFC911 03-28-2018 02:40 AM
Seems reasonable...how to attach...resting on the small branch nooks if they are somewhat perpendicular to the pipe and lashed to the trunk? What if the branch nooks aren't doable...how best to secure the pipe?
dad911 03-28-2018 04:19 AM
LOL I'll accept fraud, been called worse.
We built tree forts by nailing scrap lumber between 3 trees(triangle floor).... no naysayers to say it wouldn't work.... as I recall lasted longer than we needed it.....SmileWavy
Of course today we'd need permits and insurance.
sand_man 03-28-2018 04:35 AM
So, my plan is to drill through holes on each end of the pipe. I will rest it in the crook of the perpendicular branch in each tree. Then using cable, threaded through the holes of the pipe, wrap the cable around the trunk of the tree, and secure/tie the cable using Crosby clamps.
Otter74 03-28-2018 08:11 AM
Find an old piece of railroad track and secure to the two trees. Of course that won't give you the safety factor you need so you should then just cut the trees down and replace them with steel poles and bolt the tie to that.
(PS I'm kidding)
vash 03-28-2018 08:37 AM
i am so glad i dont have kids.. or trees.
sand_man 03-28-2018 08:41 AM
Now that I have a plan, the question becomes, do I put myself in harms way and climb a ladder, resting against a tree? Or do I pay someone?
ckelly78z 03-28-2018 09:15 AM
Operating a power tool, or wrenching on something close to the project at the top of a ladder can be sketchy at best. It gives you a sense of teetering on the edge of disaster. A lift of some sort is a stable platform to move around while working, and keeps the safety factor within reason. 18' doesn't sound like very high until you are holding on to a steep ladder too close to your project, and don't feel comfortable leaning back......Been there, done that !
sand_man 03-28-2018 10:50 AM
I know you're right. As a younger man, I always hated being on an extension ladder hanging Christmas lights on my house. Now as an older dude, yeah, I think I gotta break down and higher a "helper" to go up and follow my instructions. I don't need to end up a statistic...
MBAtarga 03-28-2018 01:57 PM
Solution:
http://forums.pelicanparts.com/uploa...1522270674.jpg
pavulon 03-29-2018 03:43 AM
A near or real disaster here puts in you firmly in family lore for a generation! The kids need to witness it though and it must be filmed and posted for it to live in PPOT infamy.
sand_man 03-29-2018 05:31 AM
Live streaming...A MUST!!!! :D:D
flatbutt 03-29-2018 06:31 AM
a pay per view opportunity if ever there was one!
sand_man 03-29-2018 07:11 AM
I'll sell the rights to Dorna...
But will likely end up with chitty ESPN ("new" F1 stylze) coveragehttp://forums.pelicanparts.com/suppo...eys/hiding.gif
pavulon 03-29-2018 02:53 PM
http://forums.pelicanparts.com/uploa...1522360409.jpg
wdfifteen 03-29-2018 05:08 PM
Originally Posted by dad911 (Post 9978805)
We built tree forts by nailing scrap lumber between 3 trees(triangle floor).... no naysayers to say it wouldn't work.... as I recall lasted longer than we needed it.....SmileWavy.
Oh man, sounds like our “tree fort.” My parents weren’t engineers obviously, or they would have forbidden my siblings and cousins to go near my creation. No one died, and I learned a lot about design as well as the anatomy of the opposite sex in that structure.
