Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Overspray?
In January, I picked up my car from a Restoration shop, where bare metal restoration and paint had been done to correct some old bodywork that had been from 25-30 years ago. I am the original owner.
The car looked great, but today I washed it and then I waxed it for the first time since the bodywork was done. The paint is perfectly smooth on the drivers door and the flat parts of the front and rear fenders, but everywhere else (tops of fenders, trunk lid, etc,) the paint is slightly rough to the touch. Is this overspray, and will professional polishing make it smooth. I paid a lot of money for this work and am not happy, but I am not close to the shop.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-24-2019, 03:06 PM
dkbautosports.com
962porsche's Avatar
most likely it's over spray.
depending how bad it is there are some easy ways to remove it. a detail shop should be able to handle the job easy enough.
you could try a clay bar your self if it's not to bad that will take it off.
Old 04-24-2019, 04:41 PM
+1 on using a clay bar and then buff it.
Old 05-16-2019, 09:35 PM
Cairo94507's Avatar
You might surprised how much stuff clay bars remove. Remember to always keep the clay bar wet. I use detail spray when using a clay bar. Remember to keep folding the clay bar.
'71 914-6 #0372
'17 Macan GTS
Old 05-17-2019, 05:20 AM
