HELP!! Need Help With Paint Codes!
My dad and I are restoring a Bronco and we’re both big fans of the classic Porsche colors in the 50’s-70’s. We found three codes on rennbow along with the three digit code. PPG store says codes are invalid. Can anyone help with how we can go about getting similar paint codes for ppg or another source for the paint altogether.
1970 911 Leaf Green code: 62163 1977 911 Light Green metallic code: 266 1953 356 Palm Green code: 526 My dad and I really appreciate all the help you can give us! |
leaf green ( blattgrun ) the code is 218 used in 1972 to 1973
light green met ( hellgrun ) the code is 275 under 1978 to 1981 palm green ( palmengrun ) code is 526 used in 1950 to 1953 the names , codes and dates used are off the top of my head i could be wrong. so you may need to double check. i'm not surprised that PPG doesn't have the info your dealing with a paint CO more geared to the us car market looking for codes for porsche. you will be better off going to BASF and getting the paint you need for a basf jobber. BASF IS THE PAINT CO THAT PORSCHE USES . Even if PPG has the code they may not have the formula right so the color could be way the hell off from what it should be. when ferrari switched from basf glasurit to PPG even black wouldn't match if you had to repaint a ferrari. it was so bad ferrari switched back to BASF after 5 years. on a side note i have a 1966 bronco coming in in a month or so for new rear QTR's. the customer cut them some years ago to get bigger tires on it and now wants to return it back to stock. 'im not doing anything else other then the metal work he is going to do the body and paint work him self again. he told me all they offer are half QTR panels and he's not good at welding and doesn't want to warp them. |
962 Porsche
you were a tremendous help! thank you so much We are putting a Coyote motor in the Bronco and have put a lot of time in setting up this build to stand out. Thank you for helping with the codes and BASF! |
| All times are GMT -8. The time now is 10:56 PM. |
