Rust converter before cavity wax
Guys
Would like to find a good rust converter/dissolver in various body cavities , longitudinals, etc. I have the 3m cavity wax with wand to use after but want an initial trearment that also has a wand to reach in cavities. Most I see is just bottled or spray can that will not reach. What’s good product ? Thanks Frank
Gold71 |
I have solved this....
TPC global sells a spray gun with a 24” flexible wand with nozzle end ( wish longer but will deal with it) Includes an integral gauge for running off your compressor. Then you buy the rust conversion product that’s sprayable, there are several mfg’s
Gold71 |
dkbautosports.com
i made my own gun with a wand using a cheap chip guard gun and a long piece of plastic tubing. i simply pluged the end of the tubing then drilled lots of little holes around the end of the tube. been using it for countless years for spraying rust converter .
in fact i have a few hoses for it to also spray SEM rust shied through it. it's the only way to coat the inner panels. |
Thanks for your creative solution...those kind of thoughts also passed. I needed the gun anyway .....but the longer length solution you have devised will be on my agenda. I find it odd that 3m who makes the cavity wax ( aerosol only ) has not paired it with a rust converter . All great fun ! Frank
Gold71 |
