Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Amatuer Hour Specialist
Wellwood's Avatar
Another Air System Question
So, I did a search and didn’t find exactly what I’m looking for.
I have a 60 gallon/155 psi air compressor located in a closet I built adjacent to my garage.
As a part of the design, I fabricated a wall mounted air condenser to hopefully capture a great deal of moisture before the air enters into the garage.
Once inside, I plan on installing a simple filter dryer assembly to capture to remaining gross moisture in the system before the air travels to typical service connections for my lift, hose reel and a few tool connections. I intend to T off the outlet of the filter dryer assembly with an isolation to a desiccant filter which will be a dedicated paint sprayer connection for painting and powder coating purposes.
I have the desiccant filter in hand - looking for recommendations for the initial filter/dryer. I’ve looked at a few - but find value in the collective brain trust here.
Thanks for reading and sharing your experience/recommendations.
Old 09-25-2020, 03:56 PM
Wellwood's Avatar
PFA
Old 09-26-2020, 07:55 AM
