Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
camdon's Avatar
What paint for Fuchs?
What paint do you "do-it-yourself" guys use for the back part of the fuchs?
A few P-cars in the garage
Old 05-06-2020, 02:43 PM
E Sully's Avatar
I have read in the forum that the Rustoleum Black is very close.
Ed
1973.5 T
Old 05-07-2020, 03:38 PM
camdon's Avatar
Thank you
Old 05-07-2020, 07:41 PM
i used sem trim black back in 1985 and they still look great...
Old 05-08-2020, 08:52 AM
dkbautosports.com
962porsche's Avatar
because of wheel cleaners that maybe used and with people that will also use tire dressings a none catalyzed paint and primer is not recommended!
you would be far better off going with a 2K product.
of you don't have an air supply or spray guns this is not a problem as you can buy 2K paints and primers in spray can form. places like Eastwood , TCP , auto body tool mart sells them in different glosses. you would be looking for a satin black.
I have used the Eastwood rat rod satin black on a few things not rims I have spray equipment and a paint mixing system with the color code for the wheel color and gloss of the Fuch's.
Old 05-08-2020, 09:14 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I had the jobber mix 22 line up for me based on a chip against the factory fuch in 2003. He then gave me "flattener" to cut it to the flatness I chose if his blend did not look flat/matte enough. Worked fine and has been very resilient.
The color code would have been nice to have back then.
1981 911SC Targa
Old 05-26-2020, 09:05 AM
i used green back grat look
Old 12-02-2020, 07:56 AM
Can't go wrong with SEM Trim Black paint. Beautify satin patina, very easy to spray from rattle can (has direction fan pattern!), and very long-lasting. No affiliation.
Old 03-31-2021, 07:48 PM
Aside from SEM, Duplicor has some good quality paints.
Old 04-20-2021, 11:05 PM
