Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Porsche Crest 911SC Front Valence Conversion
Does anyone have experience updating the front valence on a 911SC to the 3.2 Carrera style with the fog light holes? If you used aftermarket parts, do you have recommendations on where to purchase and if it was bolt on or required fabrication? Were you able to reuse the existing fog lights or did you need to update them? Apologies if this isn't the appropriate forum.
Old 05-18-2023, 11:20 AM
onboost's Avatar
The 3.2 Carrera valance is interchangeable, you will also need to use the 3.2 style fog lights.
Aftermarket parts (assume you mean fiberglass) will be a toss-up, some fit better than others.. if you're looking for metal, I would try Restoration Design as they make very good replacement sheetmetal for Porsche.
Lastly, it may be fairly easy enough to find these parts used.. local shop, ebay, or pelican.
RGruppe #180
Old 07-13-2023, 05:15 AM
Having done this multiple times, the existing fog lights can be used but you will need the updated Carrera fog light housings. You will also need to switch to the later style washer fluid tank (smaller in size) that sits behind the left fog light.
Old 07-15-2023, 05:19 PM
I have these available, used aftermarket and another twin slot (not pictured), all need body work. Local pickup in Sacramento CA. Link to my old posting.
911 Front Spoiler
Old 08-23-2023, 05:23 PM
Tags
911sc , front valance , porche
