Targa_PB_78_SC
What blasting media to use?
So I'm looking at my rear fenders, forward part where oil lines are on pass side. Thinking of blasting out the corner to apply a rust stop, rust inhibit paint in the area. There is no rust which is obvious.
What type of media to use? Aluminum oxide, sand walnut shells. Paint on the outside is only 5 years old and is in great shape. Want to keep stuff from sitting in the nooks to trap water where I am thinking of blasting. Maybe not blast?
BareRearedRookie |
The 9 Store
Blasting in the open makes a mess. Especially on a running car.
All used parts sold as is. |
Targa_PB_78_SC
Good to know, what I should have known, thanks
BareRearedRookie |
If you do end up blasting something, crushed glass is always my first choice. Coal slag next. Both are very affordable and somewhat easy to find. Northern Tool carries both. Tractor Supply has coal slag IIRC. Sand is never a good choice due to the amount of free silica in it which is not good for you to inhale.
Best thing you can use to inhibit rust is a quality epoxy primer. SPI (Southern Polyurethanes) makes one of the best available. Stay away from POR-15 and other "rust encapsulating" products, they don't truly inhibit rust and moisture can continue to wick in between the POR15 and the metal. Which leads to more rust. I've had clients who applied POR-15 at some point before bringing me their vehicle and where shocked at what the metal looked like after I removed the POR-15. A good quality epoxy primer like SPI's is the best thing you can use on bare metal and will provide many, many years of protection.
High quality metal, body and paint work http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/ |
Targa_PB_78_SC
Thanks for sharing your wisdom, knowledge is always appreciated.
BareRearedRookie |
Mike, this Brunox may be what you are looking for. It's an epoxy but with (I guess) phosphoric acid in it. I've had quite good success with the stuff https://www.brunoxswiss.com/brunox-epoxy
Targa_PB_78_SC
Might need a translator, I think I have something similar. The link is interesting, I can only get the Czechoslovakian language version.
BareRearedRookie |
Try this Mike. We sort of speak English around here. https://www.pacer.co.nz/category/301-brunox
For overall protection though nothing beats a proper two part (activated) epoxy. Wise old guy I learned a lot from used to tell me in regards to refinishing that "nothing good ever comes out of an aerosol can." Stuff I use will pass the aviation Skydrol test. Skydrol is a highly corrosive hydraulic fluid and if a paint passes that test it's a good indicator of it's quality. Paint is so expensive and the amount of labor required is such that you want to do it right the first time. Having a quality two part activated epoxy as your base over bare metal is a good start.
High quality metal, body and paint work http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/ Last edited by ChrisHamilton; 09-19-2024 at 09:47 PM.. |
Yeah totally agree. A good epoxy is not porous so therefore shouldn't let air and moisture in to allow rust to occur. In theory LOL
The Brunox stuff I used was in the half litre container and I used a paintbrush to put it on. It's been about a year and I put it on the rusty bit bottom left corner of the 911 back window area. No rust bumps yet. Who knows. It seemed quite happy with a regular PPG automotive primer/base/clear coat over the top. I also used some on a rusty car trailer too with some success. |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Targa_PB_78_SC
Pass side rear fenders inside wheel well
Hey, my exterior body is fine and great. However it appears there may be some rust going on between the rear fenders and the body. (As evidenced by couple of bubbles on the door jam with the striker plate). Not super serious but I’m trying to slow any progression as best I can. Does the black tarry stuff need to come off? I’m sure I can get some of it off, but not all especially in the crevices. Thinking if I hit it with a good rust inhibitor it won’t hurt. (After I do the best prep I can do in SITU). Probably best to remove as much of the black goo as I can.
It’s a Dallas/Arizona car so no salt. But it appears to have something going on here. Your thoughts are appreciated. Is there a commercial black goo I could use to fill in after the rust inhibitor is used? Or is this a no no? ![]() ![]() ![]() I guess it was answered above, get it down to bare metal as best you can: Quote:
BareRearedRookie Last edited by mike sampsel; 09-23-2024 at 03:19 PM.. |
