Need part nymber for interior trim
You can see the lower interior door jam trim needed. both sides of whatever trim and backing needed to replace. Part Number?
Thanks! ![]()
Behind the Sun
No part number for that
That is part of your carpet. Only comes on full carpet kits Try an upholstery shop to make you the cut |
ok thanks
Behind the Sun
Or mask the whole area and paint it with black upholstery paint.
Duplicolor vinyl and fabric. It would look better for sure |
you think spraying w/ Duplicolor would be better than tryng to match color and texture with a pieces fron an upholsterer?
never used it. |
Behind the Sun
Paint is cheap
If you don't like it you can always go upholstery route Put a WTB add for the pieces. Some pelicans buy the carpet set for other areas and have some left overs You never know |
right!
I’ve used it, it works well but will make the rest of your interior look old and dirty.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
| Tags |
| door trim , leather , trim |
