Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Dash repaint?
I am going to refresh my black dash board in my 1974 911. It has gotten some scratches around the switches, etc.
- Do I need to use 2k rattle can paint or is regular spray paint durable enough?
- Should I go flat or satin?
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 11-11-2024, 11:38 AM
I have used duplicolor in the past, vinyl/ plastic paint. Works well but once you do your dash you’ll want to do the rest of the plastic and vinyl.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 11-22-2024, 08:38 AM
Sooo true, good that was the plan from the beginning!
Rob Richardson
1974 911S
Turbo flares
Old 11-22-2024, 09:51 AM
We typically use SEM Hot Rod Black, but that is not a rattle can. They sell it as a system with activator and all. My opinion is it's worth buying a cheap paint gun and masking everything to use it. It's very durable and has the right finish.
Old 11-27-2024, 11:29 AM
Ooffenhausen, thanks for your reply. I have already gone ahead and used SEM black trim paint as recommended earlier. The results look great. I will have to see how durable it is in the long run.
Rob Richardson
1974 911S
Turbo flares
Old 11-28-2024, 09:10 AM
Seems to be a post missing from this thread that had some other recommendations. Believe it was the first response to my post. Either that or I have been breathing too many paint fumes??
Rob Richardson
1974 911S
Turbo flares
Old 11-28-2024, 09:15 AM
For refreshing your exterior design on the dashboard, a 2K rattle can is the better choice for durability, UV resistance, and a factory-like finish. Regular spray paint may not hold up well to wear and tear.
Old 03-12-2025, 04:08 AM
