Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Rear reflector removal
Help!
How to remove the rear reflector to replace the rubber trim/seal below?
HowTay
Old 03-09-2008, 04:16 PM
3.2 CAB's Avatar
What year, etc.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-09-2008, 10:23 PM
You actually just carefully pry the top of the reflector with a flat protective coated object (screwdriver covered with 100mph tape) between the plastic reflector and the metal, you won't be able to get all the way down to the clips. Just work carefully back and forth until all of the top clips are lose and the reflecter is about 3/8" away from the body on the top edge and then you should be able to pull the whole top free and rotate it down like a hinged tailgate which will free the bottom clips.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-10-2008, 12:23 AM
'78 SC
Looks like I got my answer with the last reply.
Thanks all!
HowTay
Old 03-10-2008, 09:47 PM
