1984 Rear Reflector Removal
Got home today, and alas.... there it was in the mail: a brand new mint rear center reflector for my 1984 Carrera Targa with the BLACK lettering!! Better than a Red Rider BB gun on Christmas morning...
That being said, does anybody have good instructions on how to remove the existing reflector? I have looked at it and don't see an easy way, all help is appreciated! |
on an 84 it just pops out. There are two rows of fasteners that need to be very gently pryed out and it will come free.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I know the 87-89's had the clips, but I thought these were bolt-on? Is there an insert that the reflector bolts onto that you pry out? For reasons you can imagine I don't know if I can bring myself to pry it off!
I replied to your PM, I will snap some pics here shortly to show how it is fastened....
Cheers
here are the pics.
This shows the clips on the back of the reflector.... ![]() this shows how they are spaced on the reflector...... ![]() Cheers
Thanks Jeff, your help is much appreciated
As jeff said, GENTLY (and I'll add SLOWLY) pry it off! I recently removed one from my 83. The thing I found is that those 3 center clips are actually glued on to the reflector section. Apparently age weakens those glue joints as a couple of mine detached at the glue joint as I carefully, gently and slowly pried it off. I am going to reglue mine once I have finished playing around with refinishing it, but you should not have this problem as you are putting a "new" one on. Good luck!
Shane - 1984 928S |
I will definitely be careful and take note of the clips. Of course it's "new" in the sense that it's never seen a car and in absolutely mint condition. Like I said, better than Red Riber BB gun on Christmas morning!!
