Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
robmog's Avatar
welding technique ?
i'm doing ok with my mig welds.
however, what's the cure for blow thru?
should i increase or decrease wire speed?
i already have power dialed all the way down.
opinions?
thanks
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 05-27-2008, 04:58 AM
3.2 CAB's Avatar
Smaller wire might help. What size are you using now?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-27-2008, 09:41 AM
robmog's Avatar
.025
i burn through after about 1/4 inch.
could i be moving too slow?
if i pause and restart, no problem, but it doesn't look too clean
bob
1972 E pos
someday....
Old 05-27-2008, 01:14 PM
How much of the wire is sticking out when you start. If it is too short it may cause burn through.
1972 911T MFI
1995 911 C2
Old 05-27-2008, 03:27 PM
robmog's Avatar
usually start with 3/8" exposed and work about 1/4" from the surface.
i usually push the puddle.
bob
1972 E pos
someday....
Old 05-27-2008, 03:48 PM
Are you welding sheet metal? Have you seen the video on this page?
http://www.mig-welding.co.uk/thin-metal.htm
Rick
88 Cab
Old 05-27-2008, 10:02 PM
robmog's Avatar
great link, what a coincidence, that's what i'm already doing with my "pause and restart" technique.
i just didn't know it was kosher. its true the welds are a little over-penetrated. thanks to all for their input.
bob
1972 E pos
someday....
Old 05-28-2008, 03:01 AM
Slumlord
Porsche_monkey's Avatar
Faster wire feed=more current=more penetration=more burn through
Less wire stick-out=more penetration=more burn through
Slower travel=more penetration=more burn through
Hotter gas (CO2)=more penetration=more burn through
So use M5 gas, longer stick out, lower current and higher travel speed.
You should also stitch weld, maybe 1/2-3/4" at a time to avoid burn through.
Old 06-06-2008, 11:51 AM
