-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   When to use primer (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/440039-when-use-primer.html)
Gordon Rankin 11-07-2008 09:53 PM
When to use primer
I have a straight white clean fender to put on my silver car. Do I need to primer it first or just sand and apply the new paint?
Gordon Rankin 11-09-2008 03:56 PM
Anyone?
Or is the answer already here and I missed the thread?
Can someone link me to it?
Gordon Rankin 11-09-2008 04:02 PM
I can see that this question was not clear.
Should I put primer on the white fender or just paint it with silver after sanding?
If I should use primer, what primer should I use?
When I sand, what grades of sandpaper should I use?
BTW, this is not a trick question.. I really don't know much about paint.
cgarr 11-10-2008 05:01 AM
I will tell you what I did. When I repainted my black Carrera the only thing I primed was the spots that had filler, otherwise I just sanded the original paint and shot it.. I used a single stage paint, I don't know if prep would be different with a base and clear?
http://forums.pelicanparts.com/paint-bodywork-detailing-forum/410852-painting-weekend.html
http://i30.photobucket.com/albums/c3...1/100_6942.jpg
3.2 CAB 11-10-2008 08:33 AM
Good, factory paint is a good base primer itself. IF, it is in good shape. No rock chips, cracking, checking, flaking, etc. If the paint is good and no damage, some have just used a scuff pad, and then a tack rag, to get rid of what little dust may be there, then prep-sol, before shooting the color. I have stated somewhat simplified prep instructions, but hopefully you understand what I am trying to relate to you. Good luck!! Tony.
Schumi 11-10-2008 08:08 PM
I recently shot two stage Dupont Chroma-based paint using sanded factory paint/primer (in fair condition) as the primer. Results were good.
