rust proofing a 911 guide??
helloSmileWavy
i have a 72 911T and over the winter i will be rust chasing and applying rust protection to the whole of the car. Has anyone seen a guide for which products to apply and where to apply them for optimum rust protection? thanks steve |
If you have a 72, then it did not have galvanized steel used during construction which means by now, it already has rust(and probably lots of it). Applying a urethane coating such as POR-15 will cover the rust but in the end, will be very difficult to remove when repair is required. My suggestion, after spending 3 years fixing the rust (well covered by POR-15) is to repair the panels now while you have simple access, then use a wax based system like LPS-3 to coat the internal cavities and exposed areas of the wheel areas. If you would like, I can send you pictures of all the places to look for the rust as they are common to all of this body style and era
here you go.
from our friends across the pond (your side!). http://www.ddk-online.com/phpBB2/viewtopic.php?t=12954&highlight=rustproofing |
| All times are GMT -8. The time now is 01:02 AM. |
