Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
123steve909
Send a message via AIM to 123steve909
rust proofing a 911 guide??
hello
i have a 72 911T and over the winter i will be rust chasing and applying rust protection to the whole of the car. Has anyone seen a guide for which products to apply and where to apply them for optimum rust protection?
thanks
steve
Old 11-08-2008, 09:45 AM
If you have a 72, then it did not have galvanized steel used during construction which means by now, it already has rust(and probably lots of it). Applying a urethane coating such as POR-15 will cover the rust but in the end, will be very difficult to remove when repair is required. My suggestion, after spending 3 years fixing the rust (well covered by POR-15) is to repair the panels now while you have simple access, then use a wax based system like LPS-3 to coat the internal cavities and exposed areas of the wheel areas. If you would like, I can send you pictures of all the places to look for the rust as they are common to all of this body style and era
Old 11-09-2008, 01:45 PM
robmog's Avatar
here you go.
from our friends across the pond (your side!).
http://www.ddk-online.com/phpBB2/viewtopic.php?t=12954&highlight=rustproofing
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 11-11-2008, 04:56 PM
