-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Customized Front Bumper. (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/463414-customized-front-bumper.html)
rw7810 03-17-2009 09:35 AM
I'm not the first to do this, but I saw it on the forum and wanted to duplicate the look. Also, my car is a 70 T that someone before me in the 70's or 80's wanted to update to the later look witrh 74 - 86 style bumpers, etc. I needed a bear metal repaint and didn't want the added cost of back dating, so that's my starting point.
The update kit used metal brackets to mount to the body at the same attachment points.
http://forums.pelicanparts.com/uploa...1237307541.jpg
The front rubber strip conceled the mounting bolts. so to lose the strip meant new aluminum brackets I had cut by one of those high pressure water jet cutters.
http://forums.pelicanparts.com/uploa...1237307371.jpg
also cut a front aluminum strip and welded it in.
http://forums.pelicanparts.com/uploa...1237307415.jpg
Used some body filler to shape it up
http://forums.pelicanparts.com/uploa...1237307442.jpg
http://forums.pelicanparts.com/uploa...1237307466.jpg
http://forums.pelicanparts.com/uploa...1237307510.jpg
http://forums.pelicanparts.com/uploa...1237307629.jpg
did the same smoothing process to the rear bumper.
Buckterrier 03-18-2009 05:32 PM
Nice looking project. Post pics once the car is together.
962porsche 03-18-2009 07:36 PM
Bob , i too like that look ! did you tig the strip on the out side of the bumper as well ? if not it may crack on that seam down the road ?
SCWDP911 03-19-2009 05:01 PM
Great job Bob! going to look great. Can't wait to see it painted
carslutt 03-22-2009 06:51 PM
looks good, did u get a weight of the bumper before u did this, w/ all the stock parts and the new bumper set up? i cant wait to see this on the car.
sailchef 10-03-2009 01:31 PM
This is something I'd like to do on my SC.
In this application aren't you welding aluminum (replacement strip) to steel (bumper)?
What type of wire and gas did you use? Would my Miller 140 be able to handle this?
I like that semi custom look, while still keeping the original bumper.
rw7810 10-05-2009 06:20 AM
no, the bumper is also aluminum... I didn't weld it myself, but took it to a shop that uses a stick welder.
sailchef 10-05-2009 06:27 AM
After I asked the "newbe" question I went out to check; I threw a magnet on the bumper and it slid right off. Thanks for the reply and nice work on your car.
SCWDP911 01-25-2010 08:25 AM
bob, you ever posting some pics of this beauty? I want to see the end result!
rw7810 02-15-2010 11:34 AM
Thanks for bringing this back up.. guess I forgot to post the final product pictures. Here's what it looks like.
http://forums.pelicanparts.com/uploa...1266262407.jpg
I also painted the whole car and am pleased with the results.
http://forums.pelicanparts.com/uploa...1266262445.jpg
SCWDP911 02-15-2010 11:37 AM
very nice work Bob!
