1972 Reproduction Fuel Tank Coating and Paint
Can anyone tell me about coating and correctly (color) painting a new repro fuel tank for a longhood? Is it grey top and bottom? I saw a post on using a rubberized roofing coating, then spraying it afterward.
Is the coating necessary with the galvanized tank? Was the original coating a rust inhibitor, or for something else like shock and vibration or road rash? Thanks Matt
Matt 72 911T Targa - Sold Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat. Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!! |
(the shotguns)
possibly grey stoneguard from Wurth.
i'll be doing this with the galvanized tank i just picked up.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Get Wurth Stoneguard in either white or grey. Apply at least three spaced out coats to get the stipple. Then paint it with a grey industrial enamel. You especially want the bottom of the tank coated because of the constant bombardment of dirt, rocks, sand on the highwat which will etch into the galvanized finish and later rust.
I media blasted mine, good coat of epoxy primer, then Wurth Stoneguard with a shutz gun.. You can buy it in spray cans also, most likely need 3-4 cans I would think.
Gary R. |
the spray can stoneguard texture is not the same as that shot from a schutz gun.
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
Good to know, I was wondering what the cans used for nozzles..
Gary R. |
