-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   paint code 1970 (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/528738-paint-code-1970-a.html)
Rick B 02-28-2010 04:12 PM
paint code 1970
Does anyone know where the paint code is found on the body for a 1970 911 european specs? I can find the serial number but not the paint code.
HarryD 02-28-2010 06:55 PM
You should find a plate on the driver side door post. Looks like this:
http://forums.pelicanparts.com/uploa...1176595149.jpg
The number stamped there is the color code. You can look it up here: Porsche 911 Farbdatenbank
Rick B 02-28-2010 10:27 PM
Harry,
Thanks! the reason that I was having difficulty is that the chassis number and engine number translate to a 911 E Coupe Karmann with the engine in the right range, but I never could find a number that matched the 1970 color numbers. The color code stamped on the door post plate is 23-23-H, which is a 1971 color - blood orange. This clears up another mystery as I thought it was signal orange, but the pictures never looked like mine. I guess as mine is number 528 of 667, it could have been built late in 1970 and actually used the 1971 paint code.
Do you know if I can write / email the factory with the serial number to get all the build information like gearsets or options?
Thanks.
Rick
HarryD 02-28-2010 11:23 PM
The best you can hope for is to order a Certificate of Authenticity (Certificate of Authenticity - Owner Services - Porsche Service - Dr. Ing. h.c. F. Porsche AG). If you search here, it is of variable accuracy.
