Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
JesseA's Avatar
Lightbulb 912 Project
I have been working my a** of in the garage the last week. Scraped the whole interior to bare metal using a heat gun.
http://img69.imageshack.us/img69/4096/dsc05638n.th.jpg
http://img21.imageshack.us/img21/2261/dsc05635ae.th.jpg
To get the surface really clean will be grinding the last paint/body off using a scotch brite disc.
Does Würth´s Alu zink weld through primer give good protection? I will be welding in the floor pans in a week or so and would like to coat the bare metal so it doesn´t get infected..
How do I proceed after that? Im going for a factory look..
I had planned to go
1) Bare metal
2) Würth alu zink
3) Epoxy primer
4) Body
Should I skip the alu zink? Does the epoxy primer have any effect if it´s applied on the alu zink?
Any suggestions? I live in Sweden so I´m trying to get it as rust proof as possible.
Porsche 935 DP1 Zirkelbach
930/10
Porsche 911, 1971
2.5L on Webers
Old 02-08-2011, 01:59 AM
Bird. It's the word...
Fishcop's Avatar
Hi Jesse
Definitely use the wurth in areas you won't be able to get to after welding. Otherwise just clean up the metal well prior to laying the epoxy.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-08-2011, 03:01 AM
